wow those are pretty friggin cool, i think i might go for those, wonder what makes them road specific? as for teh shocks ill get on spares and get that sorted. thanks for the help so far
Don't forget to keep us posted once you've done the conversion
Posted 03 December 2009 - 11:30 PM
Posted 03 December 2009 - 11:34 PM
Posted 03 December 2009 - 11:42 PM
Posted 03 December 2009 - 11:47 PM
Posted 04 December 2009 - 12:00 AM
as far as im aware there is a spacer which stops the spring disloding and only happens when the car is excessively lowered and either going over a massive pot hole or hitting ramps and doing big jumps lol (highly unlikely)
im no expert id ring minitastic and have a chat with them and if ur near try their demo carhope that helps
Posted 04 December 2009 - 08:36 AM
lol well thats no good then ill have to change teh paint job and get rid of the dixie horn. i think i will try that mini tastic, if at all possible i want to do teh springs so if they can go on road ill have a look, where are they located? also thanks nick ill have a look at some of those shocks
Posted 04 December 2009 - 01:55 PM
Posted 04 December 2009 - 02:14 PM
Posted 04 December 2009 - 02:40 PM
Posted 04 December 2009 - 11:53 PM
Posted 05 December 2009 - 12:59 AM
Posted 05 December 2009 - 01:28 AM
Posted 05 December 2009 - 02:21 AM
Posted 05 December 2009 - 07:14 AM
These springs do not have the rubber or plastic seat. It is just the spring and an alloy adapter for the trumpet. Even though the coil spring and the collapsed cone were about the same height, the ride height went up by about 1" measured at the wheel arch flare. The ride is better and now you can feel and see the rear suspension working when you push down on the rear of the car. Before, it was so stiff that when pushing on the rear of the car there was no noticeable suspension movement and the tyres were the only thing flexing.
I still need to plan how I will replace the front springs. I have to deservice the air conditioning so I can get the accumulator out of the way of the upper right subframe bolt. Possibly the condenser has to come out too, in order to remove the upper right suspension arm. Luckily, the front cones still have some springginess to them, so I am not in hurry to replace them.
Cheers,
Ivan
Posted 05 December 2009 - 01:00 PM
