Where Is The Whine?
40 replies to this topic
#1 massive
massive
    Starting My Mini Up
  • 3 posts
Posted 12 January 2010 - 07:48 PM
Hello
just fitted a supercharger to my mini based blitz buggy and it's great, awesome acceleration! great sound from the exhaust, a bit of torque steer and a great big grin on my face.
I'm running a 1380 engine with sw5 cam, ported head, 8.5 comp via decompression plate, std box with x-pin diff, megajolt ignition and 1 3/4 su with ram pipe.
I'm getting around 11psi on full throttle.
BUT where is the cool whining sound?
i've listed to other supercharged mini engines on youtube and they sound great!
please advise, should i be pleased or am i missing something?
do all superchargers whine or just some and why?
Attached File  Photo0147.jpg   815.72K   153 downloads
#2 71Pickup
71Pickup
  • 95 posts
Posted 13 January 2010 - 07:40 AM
I thought they all did.
mine only tends to do it under load i.e. accelerating 3-7K RPM
N.
#3 71Pickup
71Pickup
  • 95 posts
Posted 13 January 2010 - 07:41 AM
That looks like a good install with a nice short intake pipe to the charger.
N.
#4 mike.
mike.
  • 6,176 posts
Posted 13 January 2010 - 02:06 PM
Theres abit of confusion with some of the vids on youtube. Theres a video which says the car is supercharged, but really its just got straight cut drop gears fitted.
Its the dropgears that make a loud whine, not the charger.
#5 adam_93rio
adam_93rio
  • 3,271 posts
Posted 13 January 2010 - 03:27 PM
every car ive ever known to ave a supercharger has that whine, a few i have seen are pretty much not there untill they are revved
i love the supercharger whine, so if i fitted one to my car i would be really dissapointed to be honest
its not just straight cut gears that the whine comes from
#6 Boothy
Boothy
  • 126 posts
Posted 13 January 2010 - 07:04 PM
Eatons whine on the bini so would have thought it would on yours mate
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 13 January 2010 - 07:07 PM
In true panto styleeee..
It's Behind you !
:withstupid:
Edited by Guess-Works.com, 13 January 2010 - 07:07 PM.
#8 minimotor_JD
minimotor_JD
  • 334 posts
Posted 14 January 2010 - 12:42 PM
It's Behind you !
:D
WHERE? :-
#9 ministar
ministar
  • 835 posts
Posted 14 January 2010 - 01:00 PM
It's Behind you !
:D
WHERE? :-
ITS BEHIND YOU!!!!
sorry couldnt help my self! :)
#10 Wil_h
Wil_h
  • 3,244 posts
Posted 14 January 2010 - 01:05 PM
I wonder if the above joking is in fact the answer. what I mean is because of the location of the engine it's just not audible from the driving seat. Try getting someone else to accelerate past you and see what it sounds like.
#11 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 14 January 2010 - 09:13 PM
Jameswildcooper's charged clubman was the same, you couldn't hear the charger. He was running around 10psi. Some minis I've heard at shows that are blow through charged really whine, even when stationary and revving it.
#12 camp freddy
camp freddy
  • 3,696 posts
Posted 14 January 2010 - 10:56 PM
the whine comes from the toothed drive belt, try tightening it up,
as said you may only be able to hear it from the outside...
#13 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 14 January 2010 - 11:12 PM
Are you sure? They are v belt driven, not toothed belt like cambelts. I've always thought it was the vanes inside making the noise.
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 15 January 2010 - 12:07 AM
The comment was was a 50/50 punn and some truth...
OK I know you're not going at the speed of sound, but as you're going forward the sound waves from what's behind you are getting lengthened because the medium ( the air ) in which the sound uses to travel is moving in the opposite direction, and your relative position to where the sound was produced is changing. This would lower the pitch ( maybe not by much but maybe enough )
Also in a buggy you're going to have a lot more wind and ambient noise coming at you than in a sealed cabin which is also blocking out some of the nose from behind... I'm sure that if you had a radio you're going to hear squat until you turn it right up..
I'll no wait for the
Oh no it isn't
Edited by Guess-Works.com, 15 January 2010 - 12:08 AM.
#15 Wil_h
Wil_h
  • 3,244 posts
Posted 15 January 2010 - 08:27 AM
Surely it's nothing to do with the toothed belt drive. If it was every car with belt driven camshafts would whine, and they don't.
Also, just to poo poo the ideas further, SCs run directly off the crankshaft ala Bently Blower still whine.
Maybe knackerd ones don't whine, because of worn seals or something, I'm just speculating.
