Where Is The Whine?
40 replies to this topic
#16 camp freddy
camp freddy
  • 3,696 posts
Posted 15 January 2010 - 01:04 PM
the whine comes from the toothed drive belt, try tightening it up,
as said you may only be able to hear it from the outside...
Are you sure? They are v belt driven, not toothed belt like cambelts. I've always thought it was the vanes inside making the noise.
my dad had a super charger on his 350ci v8 chevy engine and that was a toothed belt with
toothed pullys, If this one is a v belt that's probably why is doesn't whine!! they are probably
V belted so they DON'T whine..
#17 Wil_h
Wil_h
  • 3,244 posts
Posted 15 January 2010 - 06:12 PM
Surely it's nothing to do with the toothed belt drive. If it was every car with belt driven camshafts would whine, and they don't.
Also, just to poo poo the ideas further, SCs run directly off the crankshaft ala Bently Blower still whine.
Maybe knackerd ones don't whine, because of worn seals or something, I'm just speculating.
Please reas the above again. Howcan the toothed belt be responsible for the whine, it makes no sense.
#18 camp freddy
camp freddy
  • 3,696 posts
Posted 15 January 2010 - 06:47 PM
The belt my dad had was a 3'' wide belt , the super charger was a dummy (no internal vanes)
so it must have been the toothed gears and belt, I'll try and find a vid of a supercharged v8..
http://www.youtube.c...laynext_from=PL
Edited by camp freddy, 15 January 2010 - 06:52 PM.
#19 wolfie
wolfie
  • 1,149 posts
Posted 15 January 2010 - 07:44 PM
Seems the whining is coming from alot of very innacurate information, if a toothed belt makes the whine then every cambelted car on the road would be whining.............. come on get real!
"Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty."
Edited by wolfie, 15 January 2010 - 07:44 PM.
#20 rosco454
rosco454
  • 908 posts
Posted 15 January 2010 - 09:40 PM
Its not from the belt,vw g60s and g40s dont run a toothed belt as standard and the whine from those is pretty loud even in standard tune.
#21 danrock101
danrock101
  • 2,479 posts
Posted 15 January 2010 - 09:49 PM
I tell you what, I'll drive it past you and see if you can hear it then? :)
#22 adam_93rio
adam_93rio
  • 3,271 posts
Posted 15 January 2010 - 10:06 PM
have you had someone else listen to see if they can hear it, dont mean to offend by this but some people cant hear higher pitch noises
#23 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 15 January 2010 - 10:18 PM
Cam belts have a very distinct whine, but since 99% of engines with cam belts have covers over them, it gets drowned out with the rest of the noise from the engine. :thumbsup:
Having said that, there is no toothed belt on the supercharger drive, so the whine wont be coming from there.
You can hear the timing belt whine a little here while blipping the throttle, as I have a little fun on a Manchester Minis Mini Auto test night, lol, needless to say I was cra.p :D
Edited by Sprocket, 15 January 2010 - 10:21 PM.
#24 camp freddy
camp freddy
  • 3,696 posts
Posted 15 January 2010 - 11:31 PM
I had Ford Orion which had a toothed cambelt and that whined ,although the exhaust noise did drown
it some what.
And the supercharger whine WAS first hand on a toothed gear drive pully, but not on an Eaton,
as I said an Mini supercharger may have a grooved belt so it doesn't whine...
That's all I have to say.. :D
#25 Sprocket
Sprocket
  • 7,266 posts
Posted 16 January 2010 - 12:35 AM
The Eaton supercharger uses spur gears and that is why it makes a noise. The lubricant is being squeezed out from between the teeth of the gears at supersonic speeds, and it is that which makes the noise L M F A O :D NOT!! but it is the spur gears adding to the noise in the same way as transfer gears do :thumbsup:
Edited by Sprocket, 16 January 2010 - 12:36 AM.
#26 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 16 January 2010 - 02:41 PM
hahahahahahahahahahaha! :)
#27 Wil_h
Wil_h
  • 3,244 posts
Posted 16 January 2010 - 03:10 PM
Yes that sounds like a belt whining, similar to my subaru sounds at tickover, but more obvious. What it dosen't sound like is a supercharger making boost.
#28 Sam Walters
Sam Walters
  • 2,765 posts
Posted 16 January 2010 - 10:02 PM
This thread has it all.
Fluids breaking the sound barrier, wining toothed belts?
Wil_h and Sprocket seem to be the only ones with a clue.
As for Mra minis? Smack bang at the bottom of the MRA`s web page it says
MRA Minis is a subsidiary of MRA Engineering Ltd
Engineer? Really?
Edited by Sam Walters, 16 January 2010 - 10:06 PM.
#29 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 16 January 2010 - 10:28 PM
Engineer? Really?
Yeah more of an engineer than you probably think you are
#30 Sam Walters
Sam Walters
  • 2,765 posts
Posted 16 January 2010 - 11:01 PM
I seem too have got two threads mixed up, I was reading what he said about oil and super sonic speeds.
All i`m saying is take everything you read with a pinch of salt.
Hold on i'm gunna have to let it out. :D
