rang minisport today and they said that they dont know how long my order will be on hold for becuase of heritage. they took 12 months last time to deliver arches to minisport so im going to be waiting a long time lol, i will have to get an arch somewhere else i think...
Try www.scparts.co.uk plus if you ask for a catalogue (its large and very comprehensive) its good to use as a manual. Costs about a fiver or so. The panels i've had from then have been good so far, doorskins, inner and outer sills and front floorpans.
Not sure about their wheel arches but its always worth a punt. Might be worth asking other members on the forum for their input, just give them time.
thanx for that sonikk4, ill look on there for arches now, i was just wondering.... in ur project erm pictures u have loads of blue or red pins all over ur body work. i presume this is to hold ur panel work in place?? where did u get those?
I work in the aircraft industry and those pins are called Skin Pins, the different colours denote the different sizes, 3/32 red, yellow 1/8th, blue 5/32, black 3/16, white 1/4. And yes i use them to hold the panels in place prior to tacking them in.
I mainly use the yellow 1/8th and blue 5/32 all of these i have acquired over 30 years in the industry. You can buy them off Ebay, look under either Aviation tooling or Aircraft tools.
The only problem when using these is if you start welding next to them the nylon pad will melt. As an alternative there there are types that are all metal construction called Cleco. Again you will find these on Ebay but to use these you will need the special pliers to install/remove them. Again they come in the same sizes as the skin pins i mentioned earlier.
Hope this helps, just as a guide i use approx 30 of each size and find that enough.
