9973 replies to this topic
#4846 minimk1
minimk1
  • 917 posts
  • Local Club: a's of herts
Posted 06 April 2015 - 11:06 PM
Is that Inca yellow in the photos above?
It most certainly is, sprayed it myself but it was the cars original colour too !
#4847 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 07 April 2015 - 08:19 AM
Had this reading over 100 before when checking for oil pressure:attachicon.gifimage.jpg
Now to get the engine started and sort out the wiring.
Slowly getting there.
Too much is as bad as not enough, as too much pressure could blow gaskets etc(ive had it before!)
Should I be worried? I'm using 20/50 Comma Sonic and the oil was cold as I the engine wasn't running, I was just checking for oil pressure.
What do you suggest? Adjustable valve?
Also what pressure should I be looking at ideally?
Thanks,
Ian
Cut the spring down until you're left with a reasonable oil pressure, you probably want around 75 psi max. Also I've heard if you exceed the max pressure on your gauge it will soon damage it.
#4848 WMU 211G
WMU 211G
  • 201 posts
Posted 07 April 2015 - 11:10 AM
Charged the battery up and turned the car round in the garage so I can start tidying up the engine bay, been meaning to do it for nearly a year   ;-)
#4849 scrumpix
scrumpix
  • 453 posts
  • Local Club: Yeovil Mini Mania
Posted 07 April 2015 - 12:29 PM
went to Wheels day at Rushmoor Arena
Any good? Been there lots of times but didn't book in this year so didn't bother.
yes despite the damp weather some nice cars on show
#4850 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 07 April 2015 - 08:32 PM
Thanks,
Ian
There is a way to reduce the pressure, remove the pressure valve(CAUTION, spring!) Cut one tail off the spring, refit and check the pressure.
Ideal pressures are:
IDLE:
40 psi HOT
60-70 psi cold
consistant 60 psi under load
#4851 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 07 April 2015 - 09:55 PM
Made some alterations to my conversion sub frame, refitted it to the car and then trial fitted the front end back over it.
Its getting close but still needs a little work. Its just clashing in a few small areas but I have an idea of how to sort it. Just need another bank holiday weekend now so I can do them.
#4852 darkcat
darkcat
  • 398 posts
Posted 07 April 2015 - 10:00 PM
started to sand the roof with my new painfully expensive DA sander, and received my new spray gun!
#4853 Cooperman
  • 23,567 posts
Posted 07 April 2015 - 10:20 PM
Did a big service on the Cooper 'S' ready for MoT, but the washer pump has lost delivery pressure, so got to buy and fit a new one.
#4854 darkcat
darkcat
  • 398 posts
Posted 07 April 2015 - 10:27 PM
a BIG service? so you changed ALL the plugs?!
very extravagant!
#4855 BronkoMini
BronkoMini
  • 1,485 posts
  • Local Club: Mini Fixers
Posted 07 April 2015 - 10:32 PM
Set fire to some under seal.
#4856 RooBoonix
RooBoonix
  • 1,225 posts
Posted 07 April 2015 - 10:34 PM
Drove it, bought a couple of bottles of water in the shop "just incase" as I wasn't sure whether it was using water (again) or not, turns out he seems alright.
Cam.
#4857 dprac1ng
dprac1ng
  • 98 posts
Posted 08 April 2015 - 12:38 AM
Thanks,
Ian
IDLE:
40 psi HOT
60-70 psi cold
Haha... Another good one is to run the crankshaft bearings down to the copper. True story, the engine was running (not very well, I'll admit) for a good year or so with 40 psi on cold idle, and absolutely nothing when hot. A bit of gaffa tape has placed over the oil pressure gauge, because it scared us so much. It was still running when parked up in 2001.
#4858 dprac1ng
dprac1ng
  • 98 posts
Dont do that. Im only joking.
#4859 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 08 April 2015 - 06:24 AM
Recovered my lower dash rail 2 hours of swearing but worth the aggro
#4860 RooBoonix
RooBoonix
  • 1,225 posts
Posted 08 April 2015 - 07:26 PM
Lapped in 4 ball joints ready to fit, and had a look at my speedo cable as I suspect that is what's squealing behind my dash when I drive (and it did seem to have a bit of a sharp turn, hopefully fixed now)
5 user(s) are reading this topic
    Bing (1)
