Project Pandora
189 replies to this topic
#61 Pandora
Pandora
    Cadwell Event organiser
  • 1,054 posts
  • Local Club: TMF Lincoln
Posted 17 November 2005 - 11:04 PM
Well ive racked my brains for so long now on what to do im going to stick with the 7 port with twin webs, and get it sorted like ya say, so i can wup ya down the drag MUHAHAHAHA
#62 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 17 November 2005 - 11:13 PM
I reckOn it will be a well close race to be honest. :grin: Mind you, youll have a bucketfull of lag and torque steer :grin: :cry: By the time you get to the end of the strip, you would have done 3/4s of a mile with the amount youll be swerving down the track :cry: :cry:
#63 Pandora
Pandora
  • 1,054 posts
Posted 17 November 2005 - 11:22 PM
Well like i said its just all muscle, not turbo, just power straight through and onto the tarmac.
#64 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 17 November 2005 - 11:28 PM
Are you not fitting a turbo now then? :cry: Are you getting a bit scared of all those little ponies under the bonnet :cry: :cry:
#65 Pandora
Pandora
  • 1,054 posts
Posted 17 November 2005 - 11:29 PM
No not at all just from what people are saying it would be pointless having the turbo on a 7 port and trying to seal or have sealed webbers like ed's which would be hard to find.
#66 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 17 November 2005 - 11:35 PM
Tell me your kidding :cry: A turbo'd 7 port would be quality!! Its certanly not pointless. Mini shows would be boring if everyone said that. I think you should ditch the weber idea and fit a HIFF 44 with a plenumn. Cheap, easy and bloody effective. And youve still got the sweet sound of turbo whistle and dump valve blow off :cry: It would be so easy I think. Its only the webers that are the problem with turbo installs. Unless they are be sucked through.
#67 Pandora
Pandora
  • 1,054 posts
Posted 17 November 2005 - 11:43 PM
:cry: OK FOR THE LAST TIME ALL IVE WANTED TO DO IS TURBO A 7PORT AND THATS ALL IVE EVER WANTED :grin: :cry: but from what people had said it seemed pointless having a powerfull head then having a turbo wouldn't do much but i will see what can be done. But im unsure on the set up of 44's on the 7 port dont you need a adaptor for them. If i can turbo a 7 port then i will do it.
#68 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 17 November 2005 - 11:51 PM
Give me like 5 minutes and Ill put up a very quick scetch of how to do it. Nothing is ever pointless when it comes to things like this. If your fitting a 7 Port along side a turbo, it just means you dont have to boost the motor as much as a 5 port to get the same power. Also, the inner two cylinders wont run slightly leaner than the outer two like they do on a 5 port. The more you think about it, the more it makes sence :grin:
#69 Pandora
Pandora
  • 1,054 posts
Posted 17 November 2005 - 11:53 PM
LOL great now having a quick word with ed we may go injection as well for those winter starts.
#70 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 18 November 2005 - 12:13 AM
Well heres the quick scetch. Sorry its not the best but all my pencils are tucked away in my cupboard. I think this will work perfectly. If you was to use injection, just dump the Su and fit the injectors on the outlets of the plenumn. sorted :grin:
#71 Pandora
Pandora
  • 1,054 posts
Posted 18 November 2005 - 12:14 AM
O right i get ya, now would it all fit under the bonnet :cry:
#72 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 18 November 2005 - 12:20 AM
I bet you would have more room fitting a plenumn to the side of the head rather than a pair of webers and filters. Remember you will have to have a plenumn in front of the webers/throttle bodies anyway to feed them with the compressed air. If the pipes in the way of the rad, just run it the other way. Its not like its going to be in the way of a carb cause there isnt one at the back of the head.
#73 Pandora
Pandora
  • 1,054 posts
Posted 18 November 2005 - 12:22 AM
Well wouldnt the engine have fuel probs, i was thinking more with two 44's one either side with plen on them.
#74 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 18 November 2005 - 12:27 AM
Not if the plenumns got the right ammount of tapper on it. If your thinking the carb cant flow enough, Ive seen them flow enogh for 225+bhp. Putting 2 on means that youll have to set and match them perfectly then. With the single, each cylinder is getting the same fuel mix.
#75 Pandora
Pandora
  • 1,054 posts
Posted 18 November 2005 - 12:34 AM
OK well i'll check around thanks for setting me straight as it were lol
