Florence My '97 Cooper
665 replies to this topic
#496 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 01 May 2012 - 09:51 AM
Cheapskate!!
#497 bcjames
bcjames
  • 2,741 posts
Posted 01 May 2012 - 11:04 AM
I've got some JCG ones to go on it locked away in a box. Although that kit might be worth more off the car than on it :lol:
#498 bcjames
bcjames
  • 2,741 posts
Posted 01 May 2012 - 03:48 PM
Great service by Swiftune. I ordered this around 3pm yesterday and it arrived at lunch time today.
Swiftune SW5i cam by bcjamesmini, on Flickr
I just need the timing chain now and I think it's all ready to go then!
#499 nev_payne
nev_payne
  • 2,249 posts
Posted 01 May 2012 - 05:52 PM
What exactly are you painting on the engine anyway? Looks freekin' sweet as it is.... and soooooo clean. :ohno:
#500 bcjames
bcjames
  • 2,741 posts
Posted 03 May 2012 - 09:33 AM
It took me two hours to get the old number plates sticky stuff off the boot lid :lol: New one is now on. Really smartens up the rear, the old ones had really faded. Not quite convinced on the oversized plate though.
Mini Cooper by bcjamesmini, on Flickr
I'm also locked out of the boot >_< The key won't turn.
Engine building panic is also on! Panicccccccc!
#501 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 03 May 2012 - 09:44 AM
I like the number plate it makes Florence look even smaller :lol: ....dinky!
Good luck with the engine O_O I'l be following that closely so take lots of pics
#502 bcjames
bcjames
  • 2,741 posts
Posted 03 May 2012 - 09:53 AM
It does, I like the small mini look rather than the wide low one.
The engine, hmmmm. I'm contemplating doing it all myself now so it gets done. Scary.
#503 nev_payne
nev_payne
  • 2,249 posts
Posted 03 May 2012 - 10:02 AM
Bah... my little run-in speech got deleted :(
Oil: Change every 50 miles for the first 200 miles. Then 300, 600, 1000, 2000. Change the oil filter twice in the first 200, then at 600, then 2000. The first 2/3 changes will look like the engine's just done 10 rounds of LeMans. If anything looks suspicious on the sump plug or in the oil after the 600 miles oil change, abort and inspect.
Coolant: I made the mistake of leaving mine in for too long, dumping loads of crap into the expansion tank. Change it out after 100 miles, then again at 1000. On the first change it'll stink to high heaven and probably be full of engineering grease and swarf.
Driving: Stay under 3000rpm on all gears for the first 3000 miles and don't force gear changes. If it won't go, come back out and double press the clutch, try again. Don't sit there revving the nuts off your new engine either. Grandad driving until the 3000 mark.
Sounds: SirD's engine sounds completely different with the gearbox changes and X-Pin diff. Things will be much tighter sounding, and the usual sounds you'll instinctively listen out for will be gone. Have a good long listen to how the engine sounds when doing any gear changes, the idle, when the breaks are on (vacuum will adjust the idle) etc. Know what to listen for that's normal and what sounds like it's still rattling.
Need to get a large plate myself - where'd you source that one to?
Edited by nev_payne, 03 May 2012 - 10:05 AM.
#504 bcjames
bcjames
  • 2,741 posts
Posted 03 May 2012 - 10:22 AM
Hey Oli. I copy & pasted what you'd put in to word yesterday to ensure I had a copy of it, but thanks for posting again. I drove to work yesterday and I never seem to go much above 2500rpm anyway, aside in third down the slip road where i went up to 3000 :lol:
I bought my plates from ftp_plates on eBay, they were £16 for the pair :thumbsup: They are 'show plates', so correct for a pre-EU style car.
Steve if you spot this, if you've still got dealership stickers in the rear window of Paddy, could you take a measurement for me please? I've replaced mine but I'm sure it's not right.
I'm painting today :teehee:
Arches primed by bcjamesmini, on Flickr
Edited by bcjames, 03 May 2012 - 10:34 AM.
#505 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 03 May 2012 - 11:31 AM
Hmm, my running in technique usually involves the length of my drive!!
#506 bcjames
bcjames
  • 2,741 posts
Posted 03 May 2012 - 11:33 AM
There's loooooads of different running in ideas out there. I'm making a list of them and then picking my favourite. Plenty of oil and filters in stock!
#507 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 03 May 2012 - 11:36 AM
The JCG one?
#508 bcjames
bcjames
  • 2,741 posts
Posted 03 May 2012 - 11:39 AM
That's the one. I'm sure mine doesn't fill the gap as much as the old one would.
#509 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 03 May 2012 - 11:41 AM
29.5cms by 5.5cms....Ha haaaaa god im sad I know that
#510 bcjames
bcjames
  • 2,741 posts
Posted 03 May 2012 - 11:45 AM
Haha just like that :lol: Thanks Steve.
I've got the heating on in the garage for my painting, it's warmer in there than it is in the house!
