Nora - Mk3 - Back On The Road After 2 Years!
90 replies to this topic
#31 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 26 May 2010 - 09:55 PM
Brakes bled, few niggles sorted - She's ready to go!! :P
No idea what will happen, but at least, if she fails, we'll have a definite list that we need to sort out - But I'm hopeful, lol :P
All insured for the year now though - Couldn't find anyone who would insure her for the day, as she's 12 years older than I am, lol :withstupid:
Everyone keep their fingers crossed for us! >_<
#32 1984mini25
1984mini25
  • 8,850 posts
Posted 26 May 2010 - 10:05 PM
It might just be me, but that front tie bar also might be a bit bent.
Yeah, think you might be right!! :P K spotted it when she was up in the air ... not entirely sure what's going on there! :withstupid:
Mind you - I think the bushes have worn slightly on the tie-bars anyways, so will be taking a closer look at that when I can - I have some more here that I can swap with, if it is!! >_<
Thanks, Karl! :P
Blimey maybe my eyes aren’t as bad as I thought, how exactly they end up bent from normal driving i can't work out, but oh wells.
And fingers crossed for the mot.
#33 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 26 May 2010 - 10:21 PM
She'll be fine *Fingers crossed*
#34 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 26 May 2010 - 10:40 PM
Reggie's are bent, from when he was on an A Frame! :withstupid: :P
Thanks both! >_< *gulp* :P
:withstupid:
#35 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 27 May 2010 - 01:35 PM
Failed! :cry:
Both side lights aren't working - Though they were the other day!
Rear number plate light not working!
(I swear all of these were fine! :P)
Rear brakes aren't very efficent - I think they need new cylinders in both, really?
And - the O/S handbrake doesn't lock.
That's it! :wub:
Her body is solid - The only rust he found was surface rust!! ;D ^_^
Mind you - He checked her emissions, and they were off the scale!!! :errr: But Nora's too old to get failed on them!! :cry:
Will sort that out once she's through her MOT! ;)
#36 Mini-Mad-Craig
Posted 27 May 2010 - 02:21 PM
Not much then! ;D Best of luck with the re-test and well done ^_^
#37 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 27 May 2010 - 02:30 PM
Failed! :cry:
That's it! :wub:
If you are changing the wheel cylinders get the S type to suit the front brakes.
The rear compensator valve may be the problem. I struggle with my rear brakes at MOT time every year.
#38 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 27 May 2010 - 04:06 PM
Mmmm, OK - I think a trip to MiniMail might be in order! ;D
They weren't very effective at all, lol :errr:
Front brakes are OK, actually - Much, much better than the drums! But I think we'll look into the options that you mentioned earlier - Just for a bit extra ooompf!!
I am proud of her though!! :P I think she's done amazingly!! ;)
I'm off to drive her home now!! ^_^ Meep meep!! :cry: :wub:
#39 gregh55
gregh55
  • 1,706 posts
  • Local Club: naaa
Posted 27 May 2010 - 04:31 PM
jean, i got a few brand new brake cylinders in boxs in my shed if you need them asap
#40 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 27 May 2010 - 07:39 PM
Cheers, Greg - I'll have a word with K - He's got the day off tomorrow, so will see what he wants to do! :wub:
Much appreciated!! ^_^ ;D
#41 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 04 June 2010 - 11:50 PM
Got some brake cylinders now! Thanks hugely to Min-its!! :lol:
One side is all sorted and bled - Just the other one to do tomorrow :D
Ball joint did have some play in it, but we've tightened it all up again and it's much better now! :thumbsup:
Still need to work out this side-light issue though. :errr:
Everything was working fine the other day, but now, she has no front, nor rear side lights - Rear lights don't even work when the lights are on main/dipped beam?
But the brake lights and indicators work fine!! :P
She's also lost her numberplate lights!?
Wondering if it's all because of a connection or an earth maybe - Could be a fuse, but she's only got 2 on the whole system, so don't think it is, as we've still got some lights!! :ermm:
#42 82hle
82hle
  • 100 posts
Posted 05 June 2010 - 12:50 PM
Got some brake cylinders now! Thanks hugely to Min-its!! :turtle:
One side is all sorted and bled - Just the other one to do tomorrow :)
Ball joint did have some play in it, but we've tightened it all up again and it's much better now! :)
Still need to work out this side-light issue though. :dontgetit:
But the brake lights and indicators work fine!! :ermm:
Looked at the diagram in the haynes manual - the light switch is fed by a brown wire - no fuse - but the sidelights (front and rear then pass through an inline fuse - not the one in the fusebox - if you can locate the inline fuse you will probably have a bad connection there. I had the same problem on my 82 hle and it was the fuse, but by 82 the sidelight fuse is in the main (4 fuse) fusebox.
Mart.
#43 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 05 June 2010 - 06:13 PM
Hi Mart,
Thanks for the info! It did actually turn out to be the in-line fuse area! It was all the connections up in that top right corner - The one for the rear loom etc. Cleaned all that up and she's as right as rain!!
So, now have fog lights, side lights, rear lights, numberplate lights!! :turtle:
However, got a problem with one of the brake cylinders :)
We were just bleeding the system through and the bleed nipple's thread has stripped & also taken the thread of the cylinder with it :) It's now chucking brake fluid everywhere!
Have sent a begging message to Greg (^^) - So fingers crossed!!
Otherwise - No MOT on Monday :dontgetit:
#44 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 05 June 2010 - 06:22 PM
Greg's absolutely amazing!!!! :P :) :)
You've saved our bacon!! :dontgetit:
Thank you! :turtle:
... Work resumes on Nora tomorrow & hopefully shouldn't take long to sort!! (We've got a house to work on tomorrow!) :ermm:
But for now, I'm off to cook a nice Thai meal :ermm:
#45 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 07 June 2010 - 10:33 PM
MOT in the morning - Wish us luck!! :(
