Project Mini
#196
Posted 23 January 2006 - 09:40 PM
#197
Posted 23 January 2006 - 10:00 PM
#198
Posted 23 January 2006 - 10:07 PM
especially if doing your own frame set-up!
#199
Posted 23 January 2006 - 10:09 PM
#200
Posted 24 January 2006 - 09:12 PM
#201
Posted 24 January 2006 - 11:25 PM
Your quite right.And theres the fact that it says it dosent fit a R1, only a honda blackbird
Well update, fan switches on when engine overheats. And spent nearly 3 and a half hours talking and showing off my mini to Adreniline Junkie. Think he was pleased. :grin:
#202
Posted 25 January 2006 - 12:15 AM
Right, I'm back, have got some food... and now i'm here to report back.Your quite right.And theres the fact that it says it dosent fit a R1, only a honda blackbird
Well...
Joe..... absolutely amazing. Very impressed.
I took lots of pictures, so will send some of the better ones your way Joe, then you can post them on here if you want.
Well basically, i'm very impressed with the whole project, its at a point whereby, apart from the distinct lack of brakes, it could be driven. Something which i am very much looking forward to seeing! :grin:
Heard it running too....
I could jabber on for a bit longer, but im not going to, but Joe has done an incredible job, the pictures certainly don't do it justice, its very impressive.
Heh.. looking forward to seeing it again!
Nice to meet you Joe :cool:
Adam
#203
Posted 25 January 2006 - 08:06 AM
Thanks for the good feedback. It's good when your doing something different that someone takes an interest.
Hopefully next time it will be up and running(with brakes) :saywhat: .
Will pm my email to send us some of the hundred or so pictures you took,
Feel free to post some if you wihs.
See you again, maybe at Bingley.
Joe
#204
Posted 25 January 2006 - 11:38 AM
I didn't take quite as many as i thought... perhaps 70ish and a video clip. :nugget:Wello Adam,
Will pm my email to send us some of the hundred or so pictures you took,![]()
Joe
#205
Posted 25 January 2006 - 12:24 PM
Will send you links Joe.
#206
Posted 25 January 2006 - 12:25 PM
#207
Posted 25 January 2006 - 12:27 PM
#208
Posted 25 January 2006 - 12:30 PM
AwwHeh.. Will let Joe chose which to post.
#209
Posted 25 January 2006 - 12:32 PM
It will fit other bike engines with the appropriate sprocket adapter, the crankcase is to close to the sprocket on the R1, you may have the same problem with the latest fireblade.And theres the fact that it says it dosent fit a R1, only a honda blackbird
But all the normal stuff it should fit, hayabusa, blackbird, zzr1100, z9r, etc check before you buy though.
It will be a tight fight in a mini though, 10.5 inch between CV and sprocket centres, although could be reduced by angling the box down and the driveshafts back
David
#210
Posted 25 January 2006 - 03:20 PM
Even so i think it's a tad expensive. Don't you.It will fit other bike engines with the appropriate sprocket adapter, the crankcase is to close to the sprocket on the R1, you may have the same problem with the latest fireblade.And theres the fact that it says it dosent fit a R1, only a honda blackbird
David
