Looking a top job
What are the seats from?
Posted 22 November 2010 - 05:58 PM
Looking a top job
Posted 22 November 2010 - 07:29 PM
there from an audi A3Looking a top job
Posted 22 November 2010 - 09:51 PM
footwells welded in
Posted 22 November 2010 - 10:47 PM
thanks all the rust and crud was cleened off the inside weld through high zink primer was sprayed inside and on the back of the floor panel then welded inside and underside i had not welded the underside in this picfootwells welded in
just wondering why you chose to weld the new floor panels in over the top of the old ones (more so the passenger side), but with the foot wells cut out, wouldnt this cause a sandwich effect and if water got in between the panels, rust would start from the inside out? not knocking your work or nothing, just thought it was bit of a strange thing to do!
keep up the good work though! looking great!
Posted 11 December 2010 - 05:48 PM
Posted 02 January 2011 - 05:01 PM
Posted 09 January 2011 - 06:42 PM
Posted 15 January 2011 - 05:13 PM
Posted 03 February 2011 - 03:51 PM
Posted 03 February 2011 - 08:09 PM
Posted 03 February 2011 - 08:12 PM
thanks i sprayed the barcoat,filler primer ,bace and lacker with the doors on as i had no room under the carport to do it with them off. just spray the corners before you put the doors onReally like the colour and great work!
Just a question though, did you spray it with the doors put on or off? i can't decide if to put mine back on or not for the spray, im wondering about getting in all the corners and stuff with the doors on.
Edited by blue min 1, 03 February 2011 - 08:14 PM.
Posted 03 February 2011 - 09:21 PM
Posted 04 February 2011 - 02:11 PM
Posted 04 February 2011 - 02:16 PM
Posted 13 February 2011 - 03:21 PM
