My Engagement Ring
1514 replies to this topic
#391 Carlos W
Carlos W
  • 10,115 posts
Posted 12 January 2014 - 08:17 PM
Thanks! I've got a couple of motorbikes i'm going to sell to fund the rest of this!
I've also got the rear half of a mini that I bought to make a trailer that I've decided to get rid of!
I didn't really think it through and if I build a trailer I'll have nowhere to store it
#392 Carlos W
Carlos W
  • 10,115 posts
Posted 14 January 2014 - 03:55 PM
After much hunting I've found all the parts for the rear brakes, although the brackets that go on the back of the radius arms have seen MUCH better days and need replaced. Everything else has been cleaned up
I've also done a load more seam sealing today
#393 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 14 January 2014 - 04:36 PM
It's coming on well!
#394 Carlos W
Carlos W
  • 10,115 posts
Posted 14 January 2014 - 08:34 PM
Getting the bearings out of the top arms isn't coming on well!
#395 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 14 January 2014 - 08:37 PM
They can be tinkers. I made a puller using a penny washer cut in three, put a smaller washer behind and a piece of all thread through and hey presto. Getting the three bits to sit nicely is a pain, but a bit of grease holds them behind the bearing and a bit of heat on the outside helps as well ;-)
#396 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Thanks! I've got a couple of motorbikes i'm going to sell to fund the rest of this!I've also got the rear half of a mini that I bought to make a trailer that I've decided to get rid of!I didn't really think it through and if I build a trailer I'll have nowhere to store it
Is the RD or MT for sale?
#397 Carlos W
Carlos W
  • 10,115 posts
Posted 14 January 2014 - 08:38 PM
Both!
#398 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 14 January 2014 - 08:39 PM
That is a pig of a job, I welded a washer to the outer surface of the bearing with the needle rollers removed and used a hammer and punch to drive it out. I do like the sound of Clives idea! May have to make one myself. :thumbsup:
#399 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 14 January 2014 - 08:40 PM
Both!
PM me a price :-) I am skint but would love either, they were my first two bikes, E660DRB and D69WRB.
#400 Carlos W
Carlos W
  • 10,115 posts
Posted 14 January 2014 - 08:43 PM
I need to find the join between the bearing and the body of the arm!
I'll have another go tomorrow!
#401 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 14 January 2014 - 08:46 PM
The inside of the arm has a central parallel part and a taper at each end which leads to the bearing position. That is what makes it impossible to get a drift in, but the back of the bearing allows the bits of washers to sit on it. Its a fiddle fart of a job but works well. Do it in three bits not two as you can't get the halves in position.
#402 Carlos W
Carlos W
  • 10,115 posts
Posted 15 January 2014 - 08:01 PM
Smooooootttttthhhhhhhhhh
Pity about the small dent in the panel, there's a couple of pin holes to sort too, and a tiny bit where the A post comes down
#403 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 15 January 2014 - 08:28 PM
Any luck on the top arms yet?
#404 Carlos W
Carlos W
  • 10,115 posts
Posted 15 January 2014 - 08:29 PM
Didn't try mate, left them soaking in penetrating oil
#405 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 15 January 2014 - 08:31 PM
Not a bad idea, certainly won't do any harm.
