My Engagement Ring
1514 replies to this topic
#1186 Carlos W
Carlos W
  • 10,115 posts
Posted 13 January 2016 - 07:55 PM
A 2.4g difference across the 4 pistons, I hope to get this down to 0.1g
#1187 daenesh
daenesh
  • 423 posts
  • Local Club: Classic Car Owners Group
Posted 14 January 2016 - 09:25 AM
I've been following this thread since 2011.. im still as excited to see the final product.. thumbs up from Malaysia!
#1188 Carlos W
Carlos W
  • 10,115 posts
Posted 14 January 2016 - 02:53 PM
Today I weighed the con rods.
Although this is actually a little meaningless as they need balanced, and it may be that the heaviest rod isn't the one with the heaviest little end.
Then I made a rig for weighing the little ends
I've wrapped rubber from an old bike inner tube around the bearing in order to be able to clamp it so that the whole thing turns on the bearing only
Unfortunately I ran out of time, and I need to tighten that bolt in properly too
#1189 Carlos W
Carlos W
  • 10,115 posts
Posted 17 January 2016 - 01:15 PM
Things are progressing.
All within 0.1g
#1190 Carlos W
Carlos W
  • 10,115 posts
Posted 18 January 2016 - 11:17 AM
Con rods all to within 0.1g
#1191 Carlos W
Carlos W
  • 10,115 posts
Posted 19 February 2016 - 11:59 AM
Monthly update.
The gearbox is back from AC Dodd and currently sat in the downstairs toilet. The block, crank, pistons, and rods are with him ready for work to begin.
I've also re-primed the engine bay, the finish just wasn't good enough for a brand new engine, wiring harness etc to be dropped in to.
Here's a nice little picture of the mains being cross drilled
12628365_903751953078497_298505649762644
#1192 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 19 February 2016 - 11:32 PM
Go Carlos, go! Wax the bejaysus out of that engine bay while you can.
#1193 Carlos W
Carlos W
  • 10,115 posts
Posted 20 February 2016 - 07:39 AM
cheers Tim, I'll get plenty of lacquer on after the colour, then get it waxed up
#1194 Carlos W
Carlos W
  • 10,115 posts
Posted 23 February 2016 - 12:23 PM
Really pleased with this.
It'll do the whole thing justice now
#1195 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 February 2016 - 09:52 PM
Nice work. Cant wait to see this finished, be well worth all the effort
#1196 Carlos W
Carlos W
  • 10,115 posts
Posted 28 February 2016 - 10:34 PM
thanks mate.
I've got plans to run some brake lines tomorrow as the lacquer isn't hard enough to polish
#1197 Carlos W
Carlos W
  • 10,115 posts
Posted 29 February 2016 - 01:14 PM
Little Update.
I've fitted the Goodridge hoses to the subframe and run the pipe around the front of the subframe.
Unfortunately I'm missing the banjo bolt which goes through the 3 way connector on the o/s of the subframe so I've placed a little order with minispares including clips to secure it to the front of the subframe.
I'm going to connect the pipe work to an old reducing valve on the bulkhead so I can get all the pipes routed before I buy a new one.
#1198 slidehammer
slidehammer
  • 1,203 posts
  • Local Club: LSMOC
Posted 29 February 2016 - 01:56 PM
Love the colour, very nice looking Mini, keep up the good work
#1199 Carlos W
Carlos W
  • 10,115 posts
Posted 29 February 2016 - 02:21 PM
thank you
#1200 Carlos W
Carlos W
  • 10,115 posts
Posted 06 March 2016 - 07:29 PM
Parts have arrived from Minispares but it'll be easier to tighten the banjo bolt with 2 people, I've also put 3 clips along the front of the subframe to hold the brake pipe in place.
And, I've started polishing the crossmember, all the bulkhead is going to be exposed so it needs to look good
