Mk3 Astra Gsi
#31
Posted 15 November 2010 - 10:41 AM
First one was a '92 redtop, second a '94 X18XE (like yours) but I converted it to C20LET power with a 6-speed box. Finally, I had a third 1.8, which I sold around 5 years back.
Loved them all. As you've found, grot claims most of them but none of it is a major problem (do check where the rear springs seat on the 'chassis' legs though.
The LET was fast and quite a handfull, the redtop fantastic and the 1.8 fun. I'd say the 1.8 is excellent for a daily driver- they put out good power (as much as the 2.0 litre X20XEV Vectra ecotec?) and return awesome mpg. Need regular oil though.
#32
Posted 15 November 2010 - 05:36 PM
I've seen a few cases now of essentially standard 1.8's putting out the same power as the 2.0!. Can definitely vouch for the fun bit!!. Also glad you said about the oil, I've had a warning flash up on the screen saying "CHECK OIL" or something
Rust is a shame, but nothing I'm not used to. Will have to check to see if you can buy the repair chassis legs or whether I'm going to have to fab some up. Might as well change them both
#33
Posted 15 November 2010 - 06:44 PM
#34
Posted 15 November 2010 - 06:47 PM
#35
Posted 15 November 2010 - 10:23 PM
Check oil on the LCD screen is relatively common, the sensor is not the best.. it says 'Oil lack' if you're really low! You'll probably find the sump gasket is dropping it. Fit a gasket intended for the late 2.0 8v to fix it, it's a bonded rubber effort that is permanently fixed to the baffle plate.
All panels are available from Hadrian etc, it's all cheap too. You'll probably find the rear chassis legs are still ok though, just keep 'em waxed
#36
Posted 15 November 2010 - 10:52 PM
Plenty of oil in the sump at the mo
#37
Posted 16 November 2010 - 09:43 PM
#38
Posted 16 November 2010 - 10:36 PM
#39
Posted 16 November 2010 - 10:43 PM
£700-800 for a relatively cheap one (like mine) but not generally looked after. Will generally have some rust or other small problems for that kinda price (like mine). Th can go for anything upto and above 3k though. I would have liked one in better condition, but i NEEDED a car before next month, and funds were limited. Plus I like a play and mine wont exactly be a showroom condition car anyways, just fast!.
#40
Posted 16 November 2010 - 10:54 PM
#41
Posted 16 November 2010 - 11:17 PM
#42
Posted 16 November 2010 - 11:26 PM
#43
Posted 16 November 2010 - 11:37 PM
only picture i got off it,
impulse buy mine, came across it on ebay with about 5 mins to go, chucked a bid in and got it for 800 or something like that, that was in 2006. mine was the 1.8 as well, with calibra black leather heated seats in, mine was abused, it was my climbing wagon, every weekend it took me to scotland or wales, had my crampons still attached to my boots and put an all mighty gash/scrape down the door and wing,
god i miss that car
#44
Posted 16 November 2010 - 11:39 PM
Black ones look the best IMO.
#45
Posted 17 November 2010 - 08:11 PM
Tidy.
