Components Used On Every Mini Ever Made?
256 replies to this topic
#211 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 November 2010 - 07:27 AM
Most definately are some. Gearbox baulk rings for example, every Mini had them.
Oh no they didn't
(Sorry went to panto last night )
The type A 3 synchro's used cones not baulkrings.
and of course automatics didn't have any at all...
Edited by Guess-Works.com, 20 November 2010 - 07:33 AM.
#212 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 November 2010 - 07:33 AM
The sump plug did have two different magnets, but if that constituted a 'change' I'm not sure as it was probably only due to a change in manufacturing process and parts sourcing rather than an actual design change. Early ones had a round end, later ones square
#213 ricky_mini
ricky_mini
  • 317 posts
Posted 20 November 2010 - 10:40 AM
ball joints?
#214 jkjaxor
jkjaxor
  • 331 posts
Posted 20 November 2010 - 01:05 PM
catch plate? door hinges? inner wings? headlamp rings? scuttle panel?
jack
Edited by jkjaxor, 20 November 2010 - 01:06 PM.
#215 SolarB
SolarB
  • 1,399 posts
Posted 20 November 2010 - 02:00 PM
Nope, nope, nope, nope and.............................................................nope.
#216 l_jonez
l_jonez
  • 1,453 posts
Posted 20 November 2010 - 02:05 PM
rear brake adjuster?
#217 bakker110
bakker110
  • 426 posts
Posted 20 November 2010 - 03:34 PM
Rear hub nut?
Wiper spacers that sit on scuttle to angle the spindles?
#218 davejf
davejf
  • 280 posts
  • Local Club: CV1 and Central Minis
Posted 20 November 2010 - 05:17 PM
umm, maybe one of these?
cam followers
cam bearings
lower radiator bracket
rear drum backplate
front subframe teardrop mount
suspension trumpets
#219 mini13
mini13
  • 3,811 posts
Posted 20 November 2010 - 05:18 PM
Bonnet Prop?
#220 Pending
Pending
  • 522 posts
Posted 20 November 2010 - 05:20 PM
how about metal?
#221 Southy
Southy
  • 1,579 posts
  • Local Club: Oldham and Distrcit Mini Club
Posted 20 November 2010 - 05:25 PM
Bonnet Prop?
Mpi's were different as they curved with the bonnet where as the earlier one's were pretty much straight.
I have a feeling Ball joints are the same, the shaft for the reverse gear is also, seat mounting brackets, cam retaining plate, oil pressure relief valve cap, rubber block for mounting the wiper motor on, bracket for holding the wiper motor, petrol tank breather pipe.
#222 tomgale
tomgale
  • 561 posts
Posted 20 November 2010 - 05:28 PM
so in short, no. everything was changed
#223 Pauly
Pauly
  • 4,213 posts
Posted 20 November 2010 - 06:13 PM
Rear quarter panels? Rear valances?
#224 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 20 November 2010 - 06:25 PM
Earlier minis had magic wand setup, remote setup then changed to the common rod change
Edited by GreaseMonkey, 20 November 2010 - 06:26 PM.
#225 Southy
Southy
  • 1,579 posts
Posted 20 November 2010 - 07:08 PM
I'm referring to the shaft which sit's inside of the gearbox that the reverse gear run's on.
Also isn't the locking plate for the layshaft and revesre gear used in all the mini's?
