Components Used On Every Mini Ever Made?
256 replies to this topic
#241 mab01uk
mab01uk
  • 12,539 posts
Posted 23 November 2010 - 11:51 PM
the metal plate (cover) which the wiring loom passes through on the baulkhead of the engine bay
If you mean the black plate in the centre of the bulkhead it was not fitted to earlier Mini's with the central speedo, also there was no bulkhead hole to cover on the very late bodyshells.
#242 1984mini25
1984mini25
  • 8,785 posts
Rear subframe brake flexi hoses?
#243 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 November 2010 - 12:29 AM
One more to add to the list perhaps, top engine steady bracket (one on the block at clutch end)
Already been tried, it's a no.
#244 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 24 November 2010 - 11:27 AM
1/2" nuts? god knows is there anything yet?
#245 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 24 November 2010 - 12:03 PM
rear wheel bearing dust cover?
Any takers ?
#246 ministar
ministar
  • 835 posts
Posted 24 November 2010 - 01:18 PM
Ball joint dust cover?
Any takers for this too?
#247 Chris_R
Chris_R
  • 399 posts
Posted 24 November 2010 - 01:43 PM
Jacking points?
#248 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 24 November 2010 - 01:46 PM
Rust. A key feature of all minis. The inner wings?
#249 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 24 November 2010 - 02:05 PM
Rear Brake Shoes and return springs
rear brake adjusters
Bump
#250 mk1leg
mk1leg
  • 9,343 posts
Posted 25 November 2010 - 04:16 PM
Fulcrum pin................ :thumbsup:
This was fitted to all modles
#251 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 25 November 2010 - 04:44 PM
what bout the love they give there owners :thumbsup: thats never changed! and is a part of them ;)
#252 SolarB
SolarB
  • 1,399 posts
Posted 25 November 2010 - 04:47 PM
Is this true? Is this what we've been searching for?
Has there only ever been one design of fulcrum pin ever produced and fitted to every Mini ever made?
#253 mab01uk
mab01uk
  • 12,539 posts
Posted 25 November 2010 - 04:58 PM
No............I remember that the early ones were straight!
Confirmed:
http://www.somerford...x...=page&id=52
Item 37 2A4362 SHAFT, lower arm 2
Another early 1960s Mini suspension feature was the use of straight lower arm shafts (instead of having the more customary dip in them). The later lower arm shafts are a direct replacement for the early items.
#254 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 25 November 2010 - 07:01 PM
Mean the grease cap? If so, then yes BUT it's sort of a standard part used on other cars. Fitted to every Mini though.
Yes.
Jacking points?
No, LWB Minis don't have them and use a different jack.
Yes and yes, but again not Mini specific I don't think.
#255 mk1leg
mk1leg
  • 9,343 posts
Posted 25 November 2010 - 11:34 PM
Fulcrum pin................ :blink:
Confirmed:
My Mistake as I stripped down a 1961 a few years back and they were bent...............must of been replaced
Edited by mk1leg, 25 November 2010 - 11:36 PM.
