Components Used On Every Mini Ever Made?
256 replies to this topic
#61 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 18 November 2010 - 04:41 PM
rocker covers ?
#62 shaun617
shaun617
  • 424 posts
Posted 18 November 2010 - 05:07 PM
Horn? :thumbsup:
#63 Timinichelsea
Timinichelsea
  • 215 posts
Posted 18 November 2010 - 05:15 PM
Horn? :thumbsup:
MPI's were different.
how about drum brake backplates, including adjusters.
#64 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
In the manual gearbox, the locking plate which holds the reverse idler shaft in place never changed ( nor did the part number ) :thumbsup:
Technically not every mini had this ( blooming automatics ).... :(
Edited by Guess-Works.com, 18 November 2010 - 05:17 PM.
#65 Asphalt
Asphalt
  • 2,173 posts
Posted 18 November 2010 - 05:16 PM
Nope.
#66 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
rocker covers ?
Changed
#67 Gaffer
Gaffer
    Previously known as j519ldv. King of the spam costume!
  • 457 posts
  • Local Club: Crash Barrier Minis
Posted 18 November 2010 - 05:18 PM
battery earth strap
Negative earths?
#68 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Front bulkhead cross member and floor cross member
Edited by sonikk4, 18 November 2010 - 05:19 PM.
#69 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 18 November 2010 - 05:20 PM
rocker covers ?
Changed
how ?
#70 Tupers
Tupers
  • 4,156 posts
Posted 18 November 2010 - 05:21 PM
No they both changed.
#71 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 18 November 2010 - 05:26 PM
Chrome finisher for the rear bin? Battery box?
#72 minim@t
minim@t
  • 300 posts
Posted 18 November 2010 - 05:29 PM
rocker cover gasket? top engine stabliser mount on bulk head?
#73 Gaffer
Gaffer
  • 457 posts
Posted 18 November 2010 - 05:30 PM
Wasnt the battery box different for vans and estates?
Edit - chrome trim was changed aswell
Edited by j519ldv, 18 November 2010 - 05:34 PM.
#74 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 18 November 2010 - 05:51 PM
Different lengths were used, for automatic, Mpi etc
#75 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 November 2010 - 05:52 PM
Brake pedal/clutch bracket? not the pedals them self’s just the bracket
If you mean the pedal box then nope, there are several different ones.
People keep saying engine mounts but autos use two different ones, neither are the same as the manual mount.
Chrome finisher for rear bin was deleted at MPi and also for the ERA Turbo.
Battery earth straps did change because there were different terminal clamps used and they were different lengths in different models.
Dampers, and therefore front damper brackets, were not fitted to Hydrolastic cars.
