A series engine
autos block differnat
so are lots of componets on differnet models
But it's still an A series
only messin'. Can't actually think of anything they've carried across the line. Not even the badging is the same.
Posted 18 November 2010 - 07:03 PM
A series engine
Posted 18 November 2010 - 07:04 PM
Wheel studs head nuts/studs
Pedals? (Auto's)
wiper motor/ linkages Nvm LHD
track rod ends (2 Different Types Long & Short)
ball joints/swivle pins (Ball Joints Are Same)
wheel bearings (Taper Roller & roller)
lots of bits
fuse box? (Different in all marks)
thermostat (depends where you live and what you used)
exhaust cottonreel mount (later type minis had hangers)
locks (changed though the modles)
Posted 18 November 2010 - 07:06 PM
Pedals? - Most changes over the years, the earlier throttle pedals are smaller for a start
wiper motor/ linkages Nvm LHD - Early ones were square, later round; MPIs might be different as well
wheel bearings - Those changed along the years from balls to needle rollers
fuse box? - 2 fuse, 4, fuse and the MPI fuse box
thermostat - 82, 85, 88
Posted 18 November 2010 - 07:07 PM
Posted 18 November 2010 - 07:09 PM
Did the scuttle panel ever change? It was the same on all the models too, except maybe the clubman?
Posted 18 November 2010 - 07:10 PM
Edited by 1984mini25, 18 November 2010 - 07:10 PM.
Posted 18 November 2010 - 07:12 PM
Posted 18 November 2010 - 07:13 PM
Edited by miniman24, 18 November 2010 - 07:13 PM.
Posted 18 November 2010 - 07:14 PM
AhhhDid the scuttle panel ever change? It was the same on all the models too, except maybe the clubman?
moke
Posted 18 November 2010 - 07:15 PM
ChangedMaybe the drivers side wing on the roundnose? The passengers had an ariel hole in later ones like mine.
Posted 18 November 2010 - 07:21 PM
Posted 18 November 2010 - 07:24 PM
All changedrear stub axle?
Radius arms?
Driveshaft oil seal things?
Timing cover oil seal?
Wheel bearings?
Posted 18 November 2010 - 07:26 PM
Posted 18 November 2010 - 07:28 PM
