Finally got all the water, fuel and breather pipes all mocked up, plus a good few other things bolted on and sorted. These last few days have done my head in!! Struggled quite a few times to come up with solutions to problems as I came upon them, had to think on my feet a few times to rigg up ideas with whatever I could lay my hands on. Also I've had so much help from friends what with suggestions and making stuff for me after they hear what stage I'm at with the mini. In fact just about everyone I meet always asks how the mini is coming on! The quantity of folk that has helped me out is huge, makes me feel rather humble if I'm honest! So after a chance meeting with a mate this week and after the usual "so how's the mini doing?" he made me a heater takeoff for the head. Well he tigged a stainless pipe fitting onto a thick stainless plate so I could lower the water level and fit a air bleed pipe on top of it.
https://drive.google...iew?usp=sharing
Rather happy with what he came up with, another few pints owed! This then goes through the heated/cooled manifold for the simple reason to keep the water level as low as possible. Did a fair bit of reading on plumbing in these manifolds and couldn't really find any real plus or minus reasons for using or not using so I'm using it for the water level! I made a couple of "manifolds" for the pipes feeding the heater and going back into the lower pipe to go back into the pump. I've rigged it to firstly feed the heater and if the heater valve is closed then the water will go back up a link pipe of sorts back into the lower pipe and into the pump. This will keep a constant by pass feed from no4 end of the head and a good circulation of water when the thermostat is closed.
So it all seems to fit. Also sorted the fuel feed and plumbed in a filter. Used mostly copper pipe but I feel I need to get some sort of heat wrap sorted. Either cover the fuel pipe from the pump up to the carb or heat wrap the exhaust manifold. Fitted a pipe for the carb overflow down to the drivers front wheel side of the subframe and sorted breather pipes. So now I need to fit the tiny washer bottle and then fit some fuses so I can try electric things. Also need to clean up the center exhaust pipe and fit the bung for the Air to Fuel ratio gauge.
