The Great Estate
187 replies to this topic
#151 Pooky
Pooky
  • 5,691 posts
Posted 31 July 2006 - 02:42 PM
Oops!
It was like that a while ago, but then I took it back off to get the circlip on! :)
Oh yeah and I'm not using new bearings, hubs were off a 90's cooper.
#152 GraemeC
GraemeC
  • 7,440 posts
Posted 31 July 2006 - 08:31 PM
Hmm, there should be a spacer, usually built into one of the bearing races, that prevents the two sides of the bearing nipping up against the outer races. I would be tenmpted to strip and clean and rebuild.
When you painted the hubs did the inner races, with the needle bearings in, come out? Have you maybe mixed them up and got one side with no spacer?
#153 Pooky
Pooky
  • 5,691 posts
Posted 31 July 2006 - 08:59 PM
I'm sure nothing's changed since I took them off, they span fine with no wierd noise on before I touched them so I assumed they were fine
I don't really know about 'races' and stuff, I know these aren't taper bearings and isn't there just the inner, a flosty spacer bit then an outer bearing? then the thrust washer and castle nut?
#154 marksmini
marksmini
  • 49,441 posts
  • Name: Mark
Posted 31 July 2006 - 09:18 PM
one question where are you finding the time to do all this lmao!!!
ive spent ages doing mine, i can strip them very quick but im so fussy on how it goes back... must b clean must be resprayed or pollished etc...
must admit theres something about fitting new parts to a car isnt there.... i love it the new fresh look of something new....
anyways sorry lol
keep up the good work, looking very nice so far
mark
#155 Pooky
Pooky
  • 5,691 posts
Posted 31 July 2006 - 09:40 PM
Get yourself one of those twisted wire disc/brush things for an angle grinder! Amazing at cleaning up old parts! Check Halfords for a kit where you get two brush things and two discs (got stone but w/e) for under a tenner! Bargain! :)
#156 minivanman
minivanman
  • 3,454 posts
Posted 31 July 2006 - 10:13 PM
I got a pair off ebay... their evil when it comes to rust! just be sure to wear goggles and overalls when using em because those bits of wire dont half hurt :'(
#157 Pooky
Pooky
  • 5,691 posts
Posted 31 July 2006 - 10:19 PM
Ay! Had to pull one out fo my thumb! That went in deep :)
I always wear at least gloves goggles and tshirt now!
Edited by Pooky, 31 July 2006 - 10:30 PM.
#158 Al*
Al*
  • 1,476 posts
  • Local Club: ERC / SMOA
Posted 13 August 2006 - 02:38 PM
it's looking great buddy!.... keep it up, you are quite fortunate to have found such a solid starting shell.... it's starting to look real nice....
Al
#159 nightflier
nightflier
  • 519 posts
Posted 28 August 2006 - 01:06 PM
Quote: it's looking great buddy!.... keep it up, you are quite fortunate to have found such a solid starting shell.... it's starting to look real nice....
Al
#160 Pooky
Pooky
  • 5,691 posts
Posted 07 September 2006 - 06:09 PM
Woop! Finally got my rear hubs sorted, not going to tell you what I did wrong because its stupid! :proud: got he shoes the right way round too
I bought new Timkin taper bearings for them but, I don't think I need them now. Is it worth fitting them anyway? I've found a socket that appears to be a decent size to drift it in...what do you reckon?
that's all for now, might have the other brace bar finished soon too! :w00t:
'scuse C**p phone cam pics!
Edited by Pooky, 07 September 2006 - 06:10 PM.
#161 GraemeC
GraemeC
  • 7,440 posts
Posted 08 September 2006 - 08:43 AM
Ahh, go on - let us in on your secret! Its the stupid things that are easily overlooked and could easily leave others in a similar situation.
The socket looks OK for drifting, it needs to be slightly smaller than the bearing race so 1) it doesn't get stuck in the hub itself and 2) you can tell when the race is fully home better.
With rear wheel bearings, if they are OK when tightened up I would leave them, they don't have anywehere near the stresses and strains of the fronts.
#162 Pooky
Pooky
  • 5,691 posts
Posted 08 September 2006 - 03:05 PM
Oh ok, I'd put the hand brake bracket between the radius arm and the back plate, when it's supposed to go on side of the radius arm, it made the backplate rub against the hub on the bottom :proud:
Yeah I think, I'm gonna leave the bearings for now, the hub spins fine.
Anyone want to buy some bearings? :w00t:
#163 GraemeC
GraemeC
  • 7,440 posts
Posted 08 September 2006 - 04:08 PM
The hub will spin fine if the bearings knackered too! Put it all back together, then with the wheel on (but jacked up off the ground) check for play by trying to wobble the wheel when holding it at each side and again when holding it top and bottom. Also spin the wheel and listen for any 'rumbling' .
#164 Pooky
Pooky
  • 5,691 posts
Posted 13 September 2006 - 06:17 PM
Both hubs and brake assemblies done!, Just need shocks, drums and wheels and pretty much finished at the back except for the fuel tank...
stll, birthday coming up in just over a month :proud:
#165 DenZal
DenZal
  • 177 posts
Posted 23 September 2006 - 09:12 PM
;D :'( :w00t:
yeh annoying when that happens lol, tip i was given was to chamfer down the edges of the old bearing and use that as a drift, worked quite well. good progress mr joe! good luck getting all the fixings for the tank! minispares been sold out of some of the bolts for ages, ended up getting some from halfords, an dont forget to put the fuel sender in first!! :w00t:
