Right... still sorting out the front suspension on the 'state.
Lots of pics... sorry!
Got one of the old cones fitted, will probably get new ones before it goes on the road. Having never done anything like this before, I don't know if this looks right or not... are the angles of all the bits looking right? Will it all become clear once I try and get the hub on? lol
Speaking of hub's I've started cleaning and dismantling the disk/drive assemblies I got at L2B for £40, not too bad I thought.
They're pretty dirty so i've been using my wire brush in the angle grinder to clean them right up
few problems/concerns though,
The pistons in the calipers look well seized in so they may prove fun getting out!
I've only been working on the o/s assembly but I can't get one of the domed ball joint nuts off, tried heat and leverage so I've left it to soak in degreaser
over night and will give it a another go soon.
Oh yeah and my bottom arm pin is loose in the subframe. Is it suppose to be, the flat end looks like it should slot into the subframe but it's a bit slack
this one
What should I be looking to replace in the assemblies? The ball joints are pretty loose so they'll go, also the bearings themselves feel quite loose in the hub so I'll probably have to get them done. Anything else?
