Street Sleeper 998
235 replies to this topic
#76 1984mini25
1984mini25
  • 8,850 posts
Posted 26 February 2011 - 09:27 PM
You might find a Hif 44 or the hs6 a little too large for a 998, maybe if you were bulding a 1275 plus with a nice head and cam.
And I personally don’t see the point in twins, if set up correctly I can’t see how they would make power over similar sized single carb.
think its personal perfence really isnt it on twins
i love the sound they make when they open up :thumbsup:
True, but then there is twice as much setting up and keeping them in tune with each other.
But then I can’t see the point in over-carbing an engine, it will just be running on half choke all the time.
twrminisport - you might want some fuel clips to go on those fuel lines.
#77 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 26 February 2011 - 09:59 PM
Since now i have 6 pages of just chat of what to do with the engine i best update :D
so meet the Beast well okay the Head i got as a freebie :thumbsup: sick gotta love freebies :o
Mowog Baby :) Made in Oxford
Is it a big valve or little valve head?
Edited by Stevee, 26 February 2011 - 10:02 PM.
#78 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 26 February 2011 - 10:02 PM
yeah the lines are sorted now that was just a first run photo :thumbsup:
Twin carbs are better nominally because you get straight lines into the inlet and no bending of the air. This means they are far more effiecient than any single carb setup.
Setting up is abit more of a faf i agree but once they are setup properly then they are fine. Ive had mine on a year and they have NEVER gone out of balance even though i check them occasionally.
HIF44 are used on hot 998's commonly i know someone who has his on a 998 with a 1275 head and it goes nicely so a 998 with a sporty cam in and a decent head could be made to work well with a HIF44.
Its all down the the engine builder and what he is prepared to do and spend his money on.
Lots of different combinations will yeild different results none of which will necessarily be 'better' than another. Twins will give you more torque then a single carb setup anyway but then an sw5 cam will pull from lower down with torquey cruising charachteristics over a Kent 276 with a lumpy idle and pulls from 3k upwards
It's all down to choice really.
Head looks nice, are you going to pocket the block then run this standard or what :D
Edited by twrminisport, 26 February 2011 - 10:04 PM.
#79 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 26 February 2011 - 10:04 PM
Nikki down draft carb sounds tastey ;]
i don't know have not thought to much about a carb as of yet, thought id get the engine done and ready first
#80 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 26 February 2011 - 10:31 PM
Little
#81 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 26 February 2011 - 10:40 PM
Little
okay works for me still not going to moan :thumbsup:
still needs pocketing i take it though
#82 1984mini25
1984mini25
  • 8,850 posts
Posted 26 February 2011 - 10:55 PM
Yes :thumbsup:
#83 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 26 February 2011 - 10:57 PM
Yes you will need to pocket the block.
Some people reckon you can use 2 head gaskets and get away with it but i wouldnt chance it :/
#84 1984mini25
1984mini25
  • 8,850 posts
Posted 26 February 2011 - 11:00 PM
That’s just asking for something to go wrong :thumbsup:
Although I think I’m right in saying the 1275 head gaskets are slightly thicker than the 998 ones. :D
#85 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 26 February 2011 - 11:13 PM
you should always use a gasket that corressponds to the HEAD not the BLOCK hence it being a head gasket and go for a good quality copper one.
Dont try that trick i dont think it can end well :/
#86 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 27 February 2011 - 09:10 AM
Martin at MRA has the head gaskets to do this convertion cant remember what they are called but he dose do them
ive gotta buy a gasket kit off him anyways =] so its all good
#87 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 27 February 2011 - 11:40 AM
Im annoyed
got an update for later
put my block is rusty! yet its been dry stored in the house it could be from when i washed it i didnt dry it all out fully
but hey ho its only surface rust :bah:
right update tonight then =]
#88 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 27 February 2011 - 02:13 PM
Its amazing how quick surface rust forms. My competition motorbike after i cleaned it at about half 5 in the evening. left it til 9am the next day and the chain was coated in surface rust o.O i think i will lube it instantly in future :/
#89 DaveVader
DaveVader
  • 942 posts
Posted 27 February 2011 - 07:29 PM
I might have a few 998 bits if you need mate.
Will possibly have an MG Metro camshaft too, with followers, can't remember whether you said you had one or not but I think I'm going Avonbar Phase 2 in mine so wont need the Metro cam.
I've also got a 12G940 and... best of all... a pair of HS2 Carbs.
Proper pair, with ram pipes, ready to go on.
#90 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 27 February 2011 - 08:12 PM
Like it Dave like it :proud:
might go for metro cam unsure yet
but shall think :( by the way northants fourm still alive? it dont load for me ):
