1971 Clubman Estate....now Turbo
#121
Posted 04 May 2012 - 10:13 PM
#122
Posted 06 May 2012 - 11:08 AM
Basically yesterday I was working on the heel board, making sure it was sitting right. I got it sitting nicely against the boot floor with out having to pull it together and then went to line it up to the jig I made, but it doesn't. Its meant to be able to bolt to the jig via the subframe fixing points. I bolted one side in went to do the other but you could clearly see that it wouldn't fit.
At first I thought it was my jig that was wrong, but that is solid and there is no way that it has moved. I then measured from the centre of the holes where the subframe fixes to, on both the new heritage heel board and the original one ( didn't look like it had ever been changed nor had it been repaired before, so believe it's original).
Original measured: 1,279mm
Heritage measured: 1,283mm
A difference of 4mm.
At this point I believed it was the heritage panel at fault but after some internet thrashing I found a number of different diagrams and they all said that it should measure 1,282.7mm (50 1/2 in), which means the heritage one is spot on.
http://www.theminiforum.co.uk/forums/topic/48070-subframe-measurements/
As a result of all this my jig is now rendered useless, and now have to try and line up the heel board a different way.
I have started by finding the centre line of the car and using string pulled tight to mark it, then I found the centre line for the heritage heel board so that I can line it up with that of the car. I'm scared to do anything at moment in case I haven't got in the right place.
Has anyone had experience of this before?
Why is there such a difference from the original heel board and the heritage one?
Is there anything else I can do to ensure its in the correct place?
Your help would be most welcome, really don't want to screw this up.
Liam
#123
Posted 06 May 2012 - 01:26 PM
I wish I'd seen your link before I started on my heelboard.
http://www.theminifo...e-measurements/
My original heelboard had the centrepoints of the subframe mounting points 50 1/2" apart. The captive nuts on the Heritage item I bought aren't perfectly in line with the respective holes in the heelboard, they're a few millimetres horizontally off centre. (Could that account for your lost few millimetres?) However, it's no longer in one piece so I can't measure how far apart the captive nut centres are. The centre section on the original was in great shape so I'm using the ends as repair panels.
Adam
#124
Posted 08 May 2012 - 05:37 AM
The other option is removing your subframe jig & refitting the actual subframe to see what lines up, after all its the subframe that needs to fit back on.
I'm liking the door pods too, they look really good.
Edited by Brams96, 08 May 2012 - 05:38 AM.
#125
Posted 08 May 2012 - 11:47 AM
Neil.
Edited by norris2002, 08 May 2012 - 11:48 AM.
#126
Posted 08 May 2012 - 01:57 PM
Thanks for the heads up about, securing captive nuts on the heel board.
#127
Posted 09 May 2012 - 08:27 AM
That is an enormous amount of work you're putting yourself through, I would never be able (or willing) to do anything like this.
Respect! And keep it up, it's going to be a great car.
#128
Posted 13 May 2012 - 06:43 PM
Thanks 2Black, before I started this build I didn't know anything about car restoration, and I couldn't weld. I learnt so much just by reading other peoples build threads.
#129
Posted 03 July 2012 - 12:27 PM
#130
Posted 16 August 2012 - 09:36 PM
#131
Posted 01 November 2012 - 08:53 PM
#132
Posted 01 November 2012 - 09:07 PM
I haven't totally forgotten about it and have been doing a fair bit of work on it recently. I went a long time without even looking at the car in fear that the neighbor would complain about noise. We have now come to some sort of arrangement which allows me to progress.
When I get time I'll do a little write up to bring you all up to date.
Edited by woodenman23, 01 November 2012 - 09:13 PM.
#133
Posted 04 November 2012 - 08:54 PM
I got myself a different heater as the bottom of mine just fell out from so much rust. This one isn't perfect but for a tenner I couldn't complain.
For some reason the studs at the back on the new unit are shorter than on my original unit, as you can see in the pic below. It doesn't extend far enough to sit on the hook.
Taken back to bare metal, etch primed then top coated with black wrinkle paint.
Drilled the spot welds out of the hook and re-welded it to where it needed to be.
More to come....
#134
Posted 04 November 2012 - 09:00 PM
#135
Posted 04 November 2012 - 09:08 PM
