Heritage Panels
Posted 02 July 2011 - 09:40 PM
Posted 02 July 2011 - 09:43 PM
Also how sure are you about their work, even heritage stuff will need fettling to get to fit and isn't easy to fit.
Posted 02 July 2011 - 09:48 PM
Ive seen non gen bonnets with both hinge mountings on though?
Edited by Midas Mk1, 02 July 2011 - 09:48 PM.
Posted 02 July 2011 - 10:02 PM
Posted 02 July 2011 - 10:09 PM
Could have used a later van bonnet
Posted 02 July 2011 - 10:12 PM
Posted 03 July 2011 - 09:32 AM
Posted 03 July 2011 - 09:40 AM
If you can get any panel no matter what or who makes it to fit first time then you will have done well. I have a mixture of Heritage/Magnum/Hadrian panels on Project Erm and every single one has had to have some adjustment to get the fit right.
Also as i have learned the wings especially pattern ones do need quite a lot of messing around and force to get the gaps right, i ended up adding metal to the new bonnet to get our gaps right but both Panelbeaterpeter and shifty advocate the use of self tapping screws and some extra trimming/ fettling etc to get them to sit right.
It really is down to time and patience and if you are paying a garage to fit the panels then that will become very expensive.
I believe jagman2003 has extensively used heritage panels on his restoration so he would be the man to ask about how well they fit as he has replaced just about every single part of the shell.
Posted 03 July 2011 - 11:47 AM
Posted 03 July 2011 - 03:46 PM
Posted 03 July 2011 - 03:50 PM
Posted 03 July 2011 - 04:11 PM
Sonikk4 did the bonnet fit the slam panel with the lip removedwas the shape the same?
No not at all, i had to do a lot of work to get things looking good. have a look at the Project Erm thread and you can see what i did.
The biggest thing there was two different manufactures plus to be perfectly honest i would not buy another bonnet from SC Parts as the construction of it left a lot to be desired.
Edited by sonikk4, 03 July 2011 - 04:14 PM.
Posted 03 July 2011 - 05:14 PM
Mo
Posted 03 July 2011 - 10:52 PM
Posted 04 July 2011 - 08:00 AM
Just went on your project erm rebuild and my eyes are hurting bad 48 pages but a very good read all the same you had your work cut out there buddy but worth it. My bonnet fits ok on the wings but is more out of shape than yours at the slam panel poor as they are both heritage
Well you can do what I have done by inserting a strip but it's hard work getting it right. I had to stand back quite a few times and look at it from different angles before we were both happy.
To be honest if this was to be an every day use car there is no way I would have gone to this effort but I have learnt quite a few useful lessons from all of this and also from some of the tips from other members on here.
