Heritage Panels
#16
Posted 05 July 2011 - 07:28 AM
I used a mid '90s Rover bonnet with Heritage wings and front panel.
#17
Posted 05 July 2011 - 11:29 AM
Are they trying to align the curve of the bonnet to the curve of the slam panel? That won't work because they are not the same shape. The curve of the bonnet matches the curve of the trim, not the slam panel. The bonnet front edge has always been matched to either the grille surround or bonnet trim depending on age, not the slam panel because you should never see the bare panels together. They need to fit the grille and surround before the bonnet can be adjusted.
is this another of dans make believe stories?
the front panel of the mini van and pick up has the same curve as the car front panel, they have a built in grille, they dont have a bonnet trim, the curve is designed to follow the curve of the bonnet/front panel as shown by the pick up and van.
go look through rebuild stories and look at the pictures of cars with no grille fitted and no bonnet trim and look at the curve.
go to any good body shop that is fitting a new f/panel and wings etc and i bet none of them fit the grille before welding up as the curve is correct for the bonnet.
#18
Posted 05 July 2011 - 08:26 PM
Cheap reproduction bonnets are naff but with some work it is possible to make a satisfactory fit.
If you are using all heritage panels you should be able to get some nice gaps.
#19
Posted 06 July 2011 - 06:24 PM
#20
Posted 07 July 2011 - 07:36 PM
#21
Posted 07 July 2011 - 07:46 PM
The other option is to pm jagman2003 as his rebuild is all Heritage.
#22
Posted 07 July 2011 - 08:01 PM
#23
Posted 07 July 2011 - 08:26 PM
i have never repaired a mini yet were the bonnet curve did not fit the slam panel curve, and i have done many over 35+ years.
#24
Posted 07 July 2011 - 08:33 PM
Its only pattern stuff that causes problems.
#25
Posted 07 July 2011 - 09:37 PM
Shifty the same question to you please
Edited by jonny d, 07 July 2011 - 09:40 PM.
#26
Posted 07 July 2011 - 09:53 PM
Genuine(old) bonnet and a pattern front panel and wings
#27
Posted 07 July 2011 - 09:55 PM
#28
Posted 07 July 2011 - 10:10 PM
#29
Posted 07 July 2011 - 10:24 PM
#30
Posted 07 July 2011 - 10:32 PM
A lack in quality control , maybe a friday afternoon panel but judging from what Shifty has shown the panel should match or be very close. Ours was not and that was due to the way it was made.
Bing (1)
