euro street racer
#916
Posted 08 July 2007 - 07:02 PM
mini93 thats cool i hate welding too! be good to see some pics of the car!
minimon your right i sure have got a lot of work!
im getting really stressed that i cant do any more work on the car, i think i will be working on it non stop once i get it in the shed!
i have already planned the hole lay out of the shed, where all the tools are going and everything!
#917
Posted 08 July 2007 - 07:14 PM
#918
Posted 08 July 2007 - 07:52 PM
You may have planned where your tools are going, but you know they will end up on the floor
so so true.
i have just measured up the back garden and i recon i can squeze a 12x10ft shed in there! gives about 3ft either side without wheel arches. should be plenty of room.
its going to take some convincing though, my dad only wants it to be 12x8.
#919
Posted 09 July 2007 - 08:14 PM
Glad to be of help Joe & Andy. Will need help when I get the metro running & racing.
Andy you don't hang about do ya geez!!!!!!!!
#920
Posted 09 July 2007 - 08:53 PM
it was really good to meet you, and the box was top notch.
i have cut the main bit in as you see, just need to fiddle about with it a bit more and then i will fire over the measurements and some good pictures for you.
if i get a chance i will be making the template for the upper bit as well!
oh and if you ever need a hand with the 'tro give us a shout.
#921
Posted 10 July 2007 - 09:22 AM
No worries, that seller is a regular on turbo minis, seems a good bloke, just roun the corner to us to,
Another thing i just thought of, well a couple actally,
how about drilling some holes so you can get a socket through to undo the tricky wok bolts (like in the pic), and trimming the driveshaft joint holes so a built up inner pot joint fits through. Plus remeber so seam weld it, especially the tower tops.
I keep coming back to this thread, its really interesting me....
One quick tip, rather than drilling holes to get to the tricky wok bolts, just leave those 2 out, after all you have the weight of the engine pushing it against the subframe so its never going to come loose.
I learnt that one pretty quickly as its a right pain getting them out, after the 1st engine removal I left them out since then with no probs.
#922
Posted 10 July 2007 - 06:44 PM
these are the sort of things im sure will come to me with a highly tuned mini. but its always good to get a heads up before i start!
i might finish off the subframe one eveining this week if i get a chance, sort of job i can get stuck into while my dads car isnt in the garage.
Ive got the metal plate to triangulate the towers with so i just need to drill it and weld it on again. then i will get the grinder on the drive shaft holes as mini13 sugested, and then i can get it out the way!
#923
Posted 10 July 2007 - 06:46 PM
#924
Posted 10 July 2007 - 06:54 PM
I've been having a bit of a clearout, as I don't have a mig anymore I have a fullish reel of mig wire gathering dust, it has your name on it...
also, I bought some stainless 2.5" tube (1.5m i think) and a couple of 90deg stainless bends, as there's no way they are going to fit between my Mk1 tunnel and sumpguard i'll let them go cheap if your interested, probably a bit big for an NA engine though....
Joe.
#925
Posted 10 July 2007 - 07:06 PM
lol yeah i have managed to stick to the NA idea at the moment
#926
Posted 10 July 2007 - 07:12 PM
should be about most of the weekend, have to pop over to bazildrain to get some gas on sat morn, but don't have any plans apart from that except getting the exhaust finished
#927
Posted 10 July 2007 - 07:30 PM
#928
Posted 11 July 2007 - 05:29 PM
#929
Posted 12 July 2007 - 05:26 PM
AW.....bring your template, I'll start working on it. If you want some seam welding done, I can do it at work mate. Might as well use the firms gas & wire. No charge! buy me a few cans of boddingtons!
#930
Posted 12 July 2007 - 06:00 PM
