euro street racer
1154 replies to this topic
#976 Udo
Udo
  • 1,670 posts
Posted 07 August 2007 - 12:29 PM
just read this lot - very interesting
Seems you and I are heading the same way with engine builds except you are further along than me, nearly got the cash together for the new short block and currently cleaning up etc the head
Ian
#977 minivanman
minivanman
  • 3,454 posts
Posted 07 August 2007 - 07:58 PM
i feel like a child!
i have got my seat in my car and i have got my steering wheel in my hands, just need to make some broom broom noises.
:shifty:
Nowt wrong with that! Coming on well Andy
#978 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 07 August 2007 - 08:37 PM
yeah, done that with the new mini aswell...then realised i can drive it :D just only down the road because im not insured :shifty:
#979 andywaller
andywaller
  • 1,636 posts
Posted 10 August 2007 - 06:16 PM
udo i have been watching your project aswell, its always good to see what someone else is doing, im sort of stopping on the engine once the head is preped.
i need the engine mocked back up so i can sort out my air filter in the front end!
i have been busy with the shed recently its nearly ready to go, laying the concrete tommorrow! finally!
#980 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 10 August 2007 - 08:48 PM
more pics rewuired please
#981 Udo
Udo
  • 1,670 posts
Posted 11 August 2007 - 11:43 AM
Yeah thats one of my concerns space to fit a filter all in a standard roundnose, would like not to touch the bodywork but have a feeling it will need "adjusting".
Have you decided on the engine spec yet?
I think i've about sorted mine but was just wondering what your thoughts re crank rods pistons gearbox etc
cheers
Ian
#982 andywaller
andywaller
  • 1,636 posts
Posted 11 August 2007 - 01:10 PM
im going the other way with my filter, i want it sticking out the bonnet. i know people say its ugly but i like it!
spec wise i have some 73.5 omega pistons, the head will be fully worked with race cams and k1200 throttle bodies, and im hoping to be able to afford some SC rods and crank will be fully worked too.
there isnt anything to take pictures of atm unless you want to see my shed base that is now finished? >_<
#983 Udo
Udo
  • 1,670 posts
Posted 11 August 2007 - 04:54 PM
Each to their own on the filter!
Spec wise I'm thinking very similar omega pistons, worked head but sticking with the RS cams and TB's due to funds.
Also going for worked rods and crank. I've ruled out the SC rods!
Just need to make a decision on what to bore out too somewhere between 1293 and 1380
Anyway I'll stop filling up your thread
#984 andywaller
andywaller
  • 1,636 posts
Posted 11 August 2007 - 05:06 PM
its all right i dont mind!
i only got an LT head so that rules out the standard cams! and i didnt get any throttle bodies, the k1200s are bigger diameter and cheaper.
id go 1380, i think read the bore line up better when the block is offset bored, and the K has a 73mm bore!
#985 mini13
mini13
  • 3,811 posts
Posted 11 August 2007 - 07:12 PM
Andy,
If mine are RS cams (must check them out properly) i might be up for a swap if your interested. Of course you may just want to go the whole hog and get the mental SC cams.... in which case i'll stick with mine to avoid reshimming the tappets.
#986 Udo
Udo
  • 1,670 posts
Posted 11 August 2007 - 07:54 PM
I know I will be limiting power but I was thinking 1293 as it leaves a couple of bores in the, becoming scarce, block but I agree 1380 offset bore lines everything up better.
#987 andywaller
andywaller
  • 1,636 posts
Posted 12 August 2007 - 07:33 AM
joe, im going for the SC ones! need all the help i can get!
udo thats nice of you to save the block! im too greedy for that! but my everyday mini was saved from the scrap yard so i think i have equalled myself out in the mini world of carma :xxx:
#988 supermotolee
supermotolee
  • 1,120 posts
Posted 12 August 2007 - 08:19 AM
go 1380 udo you know you want to its gonna cost a fortune in pistons everytime you re bore it so might as well spend out once get some decent pistons and just re ring them everytime you have to aquire a new block start stock piling them now if you worried they'l dissapear lol
#989 Udo
Udo
  • 1,670 posts
Posted 12 August 2007 - 09:28 AM
Got a couple already :xxx:
Your probably right, its just my mate had a 1430 and I know how regular his HG went!
#990 danwebster
danwebster
  • 637 posts
Posted 12 August 2007 - 01:24 PM
Use a decent headgasket like me and you'll never have that problem.
Only replaced it this time round as I was changing the rings and cleaning up the valves. Almost 3 years running done on the original HG.
