Also, Andy. If the bores on the K engines are 73mm, why not make your engine a 1360? You can get 73mm pistons now, and it'll still leave one more bore before the block is scrap
euro street racer
#991
Posted 12 August 2007 - 01:29 PM
#992
Posted 12 August 2007 - 01:33 PM
To be honest the earlier suggestion was the best. Bearing in mind that ideally you want to be running forged pistons here @ £400 a set you don't want to be replacing them every five minutes.
That and the fact that in reality you won't be reboring it every month. I had my bores deglazed for this rebuild but that was it, when I split it the bores looked as fresh as the day it was built, some 10k miles and 3 years earlier. You're not going to be doing 100k miles on one of these engines, you're worrying about nothing IMO.
#993
Posted 12 August 2007 - 07:30 PM
they run a copper gasket with a sealing ring in the kit, its re-usable supposedly and it would want to be for the price.
there is somewhere local to me that makes head gaskets so i may look into this.
its 1380 all the way for me, i have already bought the pistons.
Im not really that bothered if i ever had to change the block, there are still loads of 1275's in the scrappies near me! its a hell of a lot cheaper to get another block and m/c it than it is to get another set of pistons!
i have my bulkhead!!! cheers jason!
i need to get my coilover mounts then i can finish the front end! and nearly the shell. finally.
#994
Posted 12 August 2007 - 07:35 PM
#995
Posted 12 August 2007 - 07:37 PM
#996
Posted 13 August 2007 - 06:40 PM
#997
Posted 13 August 2007 - 07:01 PM
if you still want to swap i dont mind!
actually on the subject of K's i spoke to motorworks today, they are really helpful and cant recommend them enough. i have sorted out the throttle bodies im going to use so will order them at the end of the month!
#998
Posted 25 August 2007 - 05:16 AM
I'm going to do a seat position very close to yours on my mk1 and am scratching my head on a steering column solution. I'll probably need some UJs and some way to extend the column....what exactly are you doing with yours?
Thanks,
Aric
i also need to buy a UJ for my steering column as there is no way i will ever get it at a useable angle without, there well expensive though about!
that little lot is nearly £500 so it easy to see where all my money goes!
Edited by Monte Busa, 25 August 2007 - 05:17 AM.
#999
Posted 25 August 2007 - 06:32 AM
#1000
Posted 25 August 2007 - 06:33 PM
Thanks for the note.
Aric
ive sent you a pm bud!
#1001
Posted 25 August 2007 - 06:49 PM
#1002
Posted 27 August 2007 - 01:29 AM
#1003
Posted 02 September 2007 - 12:03 PM
so good it hurts,
#1004
Posted 02 September 2007 - 01:48 PM
#1005
Posted 02 September 2007 - 08:51 PM
