Project Trig - More Fresh Powdercoat!
#181
Posted 01 February 2012 - 07:59 AM
#182
Posted 06 February 2012 - 08:05 PM
IMG_2666 by Andrew Forbes Photography, on Flickr
So this marks the start of the rebuild finally! With uni and work I don't see me getting too much time to play but I still really want it back in time for Thistle Run in June. We shall see.....
Updates will come and go but not as regular. Wish me luck!
#183
Posted 06 February 2012 - 08:17 PM
#184
Posted 09 February 2012 - 11:28 PM
Went out to the car about wish tonight and set to work sealing in the floor with some Hammerite. This floor is not going to be rusting again!
Not too cold but still 2 tshirts, 2 hoodies and track bottoms on.
Also started work on the front swivel hubs as these need rebuild but leaving them to soak in WD40 overnight.
#185
Posted 10 February 2012 - 07:30 AM
#186
Posted 10 February 2012 - 08:44 AM
#187
Posted 10 February 2012 - 10:51 AM
Couldn't recommend a pro paint job enough! All the effort put into doing a car myself in the past, for the extra cost of a pro it is well worth it.Great paint job. Am rollering mine due to costs but nextone will have a propper spray job. Just got to put it back together again now !!!
That is soooooo shiny Good luck with the rebuild fella
Thanks!
Hope its shiny enough for a mag feature or two.....
#188
Posted 11 February 2012 - 11:21 AM
#189
Posted 11 February 2012 - 07:08 PM
#190
Posted 11 February 2012 - 07:38 PM
#191
Posted 11 February 2012 - 08:59 PM
The floor took an age to dry due to the temperatures at the mo. Meant I couldn't get to work on it last night. However tonight it had finally hardened so with the day off work I got going
First thing to do was the steering rack. I had the choice of two as I bought another which I believe to be a sports pack one. Having tested them theres a 1/4 turn difference so Im not convinced however its a quarter turn less so it made the cut. It needed refurbed as the rubbers were split and the grease had all escaped, bolts were rusted solid and track rod ends had seen better days.
Had a spare refurb kit that a guy at my dads work donated to the cause after learning out his garage years ago so that was handy! After mixing and matching track rod ends from the two I got a decent steering rack together! Stripped the U bolts and painted them in silver Hammerite to protect them. Didn't repaint the rack itself as it was in pretty good nick under the grime which must have preserved it.
So here it is, all regreased, new rubbers and bolts replaced for stainless.
So with that installed I got the column in too. Got a drop bracket on it but I think I must have snapped the bolt that attaches it to the dash rail as its nowhere to be found, so its tie wrapped in place for now. This won't be the final steering wheel as I have something special in mind for that. ;)
And with that all installed I started to tackle the wiring loom. Been dreading this but once I had it all load out side by side its actually pretty simple. Thankfully I had labelled most of the old loom as I took it out. If I hadn't done this I would have had no hope in getting it done!
At this stage I was a little worried.....
Old loom on drivers side and new loom on passenger side. Almost all done but finished up early to relax in front of the TV for a while before work all day tomorrow :)
Satisfying to finally get going with it!
I can see the June 2nd target being met at this rate
#192
Posted 11 February 2012 - 09:02 PM
Thanks! Good to know people are getting inspired by what Im doing. Its just nuts and bolts being put together really, anyone could do it. :)I just finished all 13 pages and really wanted to say thank you for the inspiration. Your camera work is brill and I am really looking forward to more updates as they roll in.
Read this out to my mum and she said 'Tell him he could do a lot worse with his money at his age' which is very true. I don't smoke, drink (that often) and Im careful with my money (don't waste it on random crap) which has enabled me to do this out of my own pocket rather than the bank of mum and dad.This is cracking!, followed this from the start and that paint job is mint. Just wish i had mine to do but parents arent so sure. Im working on it. But its a great help and inspiration. Best of luck with the rebuild cant wait to see this done!
Lovely paint job! it looks amazing!
Thanks! That will please Phil the painter
#193
Posted 11 February 2012 - 09:23 PM
#194
Posted 11 February 2012 - 10:25 PM
Carefull with your money eh Andy....Thats unusual for an Aberdonian!! LOL...Trig looks great...cant wait to see him on the Thistle Run..Good luck with the rebuild, im sure you will make it on time..
Don't know what you mean......
Thistle Run should be possible but going to have to graft on in the evenings to get there! Really need to get my subframes blasted!!!
#195
Posted 12 February 2012 - 11:15 AM
Haha that is very true :) i dont drink much either or smoke. Most of it will be my money and all my efforts. Dont want help want to do it all myself as then it truly is MY car!!
Once again though, great project cant wait to see it done!
