My 1312Cc Track Toy
#16
Posted 25 September 2011 - 03:23 PM
#17
Posted 25 September 2011 - 03:37 PM
and i dont know yet, may be an evolution one made by minispares, maybe find one second hand XD
and thanks adam:) im really pleased with it, and i know, i got to be extra careful, nearly put a drive shaft through it last weekend XD
Edited by MiniclubmanGT, 25 September 2011 - 03:39 PM.
#18
Posted 25 September 2011 - 04:07 PM
#19
Posted 25 September 2011 - 05:59 PM
ps the garage looks fantastic, better than any picture
#20
Posted 25 September 2011 - 07:10 PM
#21
Posted 25 September 2011 - 09:12 PM
and thanks 8) it is, especially since i just gave it a clean and wax! 1st one since paint job. shiny!!
#22
Posted 26 September 2011 - 08:54 AM
#23
Posted 26 September 2011 - 11:09 AM
#24
Posted 26 September 2011 - 05:55 PM
so, today i got some more stuff, i got my main crank bearing back from our machine shop ( ashpoles) who machined it down for th strap to fit 8)
and i got me air die grinder and snapon die cutters, may have to recoup the money by doing some friends cylinder heads. pictures on wednesday because i broked my camea
#25
Posted 27 September 2011 - 06:29 PM
does anyone know how to lighten your own flywheel? it will be done on a lathe and then balance i just want to know where do i take the metal off and how much before it gets dangerous?
also how can i balance the con rods? can i just use a die grinder and take metal off? if so i take it il be taking it off the middle long stem -bit-.
#26
Posted 27 September 2011 - 10:08 PM
#27
Posted 28 September 2011 - 12:36 PM
#28
Posted 28 September 2011 - 01:19 PM
but i thought you could balance the con rods yourself? i saw it in an old janspeed VHR and it looked about as complicated as taking a dump? i think il have another watch...
#29
Posted 28 September 2011 - 02:58 PM
I would send the crank, rods and flywheel off to get balanced together. Im sure you can lighten your own flywheel if you have a reasonable knowlege of what your doing. but as far as the rods and crank go....Send them to the pro's....No dissrespect to your own skills, but If it were my engine doing 6500revs im prety sure id want it bang on!.
As Andy says, let the pros do it.
Getting everything balanced is extremely important, i wouldnt even consider taking material of f the rods and id probably save my money up and buy an ultralight flywheel. A billet steel one would be ideal!
#30
Posted 30 September 2011 - 09:59 PM
anyway, i got some electronical bits today, i got an ignition switch and an engine push start, this is going to be a very different modification, its going to look awsome 8)
i have been told by our engineering shop that balancing and lightening conrods is a simple process, if the right tools are in place, ie electronic scales, die grinders ect, and he told me where to do it so by a couple of weekends it should be done and the bottom end off for the final balancing!
then comes the cylinder head 8)
