Just cant get the power down!
Posted 04 February 2006 - 09:47 PM
Now I know that my engine steadie bushes are Sh*g'd and so the Unnecessary engine movement is causing knocks. But I think my entire front end is ready for a rebuild anyway replacing bushes, bearings, Balljoints etc.
As for the driving, I just cant seem to get any power down, As soon as I get my foot down it spins up and drifts across to the right hand side of the road.
My Ride height is all out as I think my front Knucke Joints are worn un'evenly causing the car to sit on a slight angle to the right.
Now is anybody else having difficulty in keeping the front end gripping, Or is it just a combo of my suspension, Cr*p tyres and Knuckle Joints?
<|Ben|>
Posted 04 February 2006 - 09:54 PM
Posted 04 February 2006 - 09:58 PM
Posted 04 February 2006 - 10:00 PM
Posted 04 February 2006 - 10:03 PM
Posted 04 February 2006 - 10:04 PM
No, Im on a serious note on this one.After some of the things you have said in the past, I put it down to the driver and his style of driving.
I only really did the "Stunty" stuff in my mini when it had the Leaky / oil burning 998 in there.
Its got a nice fresh 1275 MG metro in there now, Still a bit drippy on oil. But im getting a new clutch put in on tuesday.
My tyres are Falkens, PLEANTY of tread and decent tyre pressures (31psi all round)
Im getting ALOT of Bump steer too. :sad:
Its scary though!
Also getting alot of "Wheel spin" steer. When I change gear in the wet, if the front wheels Do spin, the car Shoots off to the right!
sounds like driver opereration error in the fact that too much right foot is applied for grip of cheapo rubber tyres and kanckered suspention thats trying to transer power to the road. in otherwords, learn how to control the rightfoot for the grip of the car, its call driving son, no traction control or drivers aids
Well said Mr Daves
Posted 04 February 2006 - 10:06 PM
There you go then...My tyres are Falkens
They are an ok tyre, but by no means the best, infact they are the next one up from Comac!
As for bump steer, get your suspension and steering etc sorted out.
Posted 04 February 2006 - 10:07 PM
I know how to f**k'n Drive!
I can pull away without spining at all (like tonight), But then I have Pedestrians Walking faster than I am pulling away!
I guess you would really have to drive it to understand.
I also know a mini has no driving aids, Ive had Four you know!
And my others drove perfectly well
Posted 04 February 2006 - 10:08 PM
Posted 04 February 2006 - 10:09 PM
ha ha haIve had Four you know!
Maybe theres just too much power for you to handle
Posted 04 February 2006 - 10:11 PM
Woah, A WHOLE 55bhp. w00t!Maybe theres just too much power for you to handle
My Peugeot is 90bhp, Its alot bigger and heavier, its also FRENCH! and that takes corners WAY better than my mini. Which is a bit embarresing to be honnest!
Posted 04 February 2006 - 10:13 PM
in which case theres serious funny going on with your suspension!My Peugeot is 90bhp, Its alot bigger and heavier, its also FRENCH! and that takes corners WAY better than my mini. Which is a bit embarresing to be honnest!
Posted 04 February 2006 - 10:19 PM
Im going to fit them tomorrow.
Now N dont have a compression tool. A mate of mine said you can still do the front shocks / dampers without this tool. Is there a nack to it?
Ive got Koni Shocks for the front and Spax for the rear.
Also got some Brand new Hi-lows. But ive only got a pair. So I can only do either the front OR the rear for now.
Thinking about just doing the front, Cutting the arches out more, and lowering it a tad.
I also need a new enigne steady. I cant use a Ultimate engine steady as the previous one ripped the mounting point out of the bulkhead!
