Strange Oil Pressure Problem.
101 replies to this topic
#76 booton
booton
  • 913 posts
Posted 04 December 2011 - 09:00 PM
thanks every one will order a set of mini spares
#77 booton
booton
  • 913 posts
Posted 04 December 2011 - 09:02 PM
http://www.minispare...id=36593&title=
this set the right one to confer
#78 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 December 2011 - 10:07 PM
Looks right and not a bad price !
#79 booton
booton
  • 913 posts
Posted 09 December 2011 - 09:44 PM
ok rebuild engine now wired it up on the floor.
i can;t seem to get the oil pressure switch to work in the floor.
i should only need to connect the wire the switch and a earth to the engine.
i have a light for the alternator.
Any suggestions
hopefully after all these changes this time i won;t have a proble
#80 booton
booton
  • 913 posts
Posted 10 December 2011 - 01:14 PM
bump
#81 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 10 December 2011 - 01:42 PM
You need to make sure there is lead going from the engine to the Negative on the battery,
Edited by liirge, 10 December 2011 - 01:43 PM.
#82 booton
booton
  • 913 posts
Posted 10 December 2011 - 01:45 PM
there is the engine turning over just the oil light not coming on at all.
#83 liirge
liirge
  • 4,097 posts
Posted 10 December 2011 - 01:50 PM
I assume you have the circuit like this
12V from Battery, connected to Light, other side of light connected to the Oil Pressure switch.
Have you tried to earth the wire to the pressure switch on the battery Negative just to check you have good wires and a functioning bulb
So 12V from Battery, Bulb, Battery Negative
Just to test
Edited by liirge, 10 December 2011 - 01:56 PM.
#84 booton
booton
  • 913 posts
Posted 10 December 2011 - 01:56 PM
i have the 12v sent to the starter and all the leads that should be there attached to the 12v. then jump leads to the body of the car.
i know it all works as it did before i took the engine out.
#85 liirge
liirge
  • 4,097 posts
Posted 10 December 2011 - 01:59 PM
Wait I'm confused, is this your own loom or the cars loom you've managed to stretch on to the engine on the floor?
Also, how do you you know you actually had a good electrical connection? for all you know this whole thing is down to a loose connection or faulty bulb, that would be a turn up for the books
#86 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 10 December 2011 - 02:05 PM
As above, test the lamp outside of its holder to make sure it works. Then confirm you have 12V going to the bulb holder and that the wire from the other side of the bulb holder has continuity from end to end. If the bulb works and your wiring is intact, test the setup by removing the wire from the oil pressure switch and holding it to earth on the engine block. If the balance of your wiring is correct the lamp should illuminate.
If you can... how about sketching your oil lamp wiring, scan it and post a picture here.
#87 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
  • Local Club: Berner Mini Club
Posted 10 December 2011 - 04:19 PM
This is why I have a mechanical oil pressure gauge:)
#88 bmcecosse
bmcecosse
  • 9,699 posts
Posted 10 December 2011 - 05:24 PM
Exactly - you have had so much 'fun' with this - GET AN OIL PRESSURE GAUGE !!!!!!!!!!!!!!! I never imagined you were relying on the switch.............
O_O O_O O_O
Edited by bmcecosse, 10 December 2011 - 05:26 PM.
#89 liirge
liirge
  • 4,097 posts
Posted 13 December 2011 - 02:48 PM
Any News?
#90 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 13 December 2011 - 06:38 PM
sounds like the original problem was caused by the oil pump gasket. sometimes the bolts are too long depending on the manufacture of the pump, with the bolts bottoming out before they really clamp down on the pump. This leads to the gasket blowing out when the engine is run up.
I've ran an engine un knowingly without an Oring between the block and gearbox and I had no problems with priming or oil pressure. I did use a smear of RTV on the mating faces of the block and gearbox though. what did happen was with the ball bearing, the oil pressure fluctuated at higher rpms quite dramatically with the engine under high load, and eventually killed the center main bearing
