Strange Oil Pressure Problem.
101 replies to this topic
#61 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 04 December 2011 - 04:26 PM
Is there a gasket fitted where the oil transfer pipe bolts to the gearbox housing?
#62 liirge
liirge
  • 4,097 posts
Posted 04 December 2011 - 04:28 PM
And you've had the oil pump off I assume
#63 booton
booton
  • 913 posts
not taken that apart the gearbox came of my other engine which i had running for two years with no problems.
so i don't think it could be that or the pick pipe.
#64 booton
booton
  • 913 posts
Posted 04 December 2011 - 04:31 PM
the oil pump is brand new, and had it working on the engine.
the problem is for the first run i primed the oil pump let it run for an hour then the next day there was no oil pressure if i re primed the oil pump then i would have oil pressure again.
but i will take it off.
some one said to pack it with Vaseline to build the pressure to prime it.
#65 liirge
liirge
  • 4,097 posts
But you did say that you had to tighten one of the bolts at the back earlier in the thread, if so the gasket may now be ruined if loose or by the tightening. I would check it and fit a new one just to be on the safe side you don't want to have to split this again to find it is that.
#66 booton
booton
  • 913 posts
Posted 04 December 2011 - 04:35 PM
well i have a brand new gasket set so these will be changed and some bit broke of anyways. when spliting so all seal will changes just in case as i have them here.
#67 liirge
liirge
  • 4,097 posts
Posted 04 December 2011 - 04:36 PM
Good move.
Whats the Oil pump like? did you look at the camshaft end where it drives the pump?
#68 booton
booton
  • 913 posts
Posted 04 December 2011 - 04:38 PM
oil pump brand new, slot drive to match camshaft piper 270 both new
#69 booton
booton
  • 913 posts
Posted 04 December 2011 - 04:51 PM
i can't get my torq wrench any where near the bolts to torque them up.
#70 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 December 2011 - 05:28 PM
The gasket should be paper thin - I suspect you have gaskets intended for an inline A series.......
#71 booton
booton
  • 913 posts
Posted 04 December 2011 - 05:57 PM
um the gaskets are quit think, i would say over a 1mm thick.
the new ones i bought are these ones.
http://www.ebay.co.u...5#ht_1843wt_750
same ones i had fitted to the engine before with the problem.
#72 booton
booton
  • 913 posts
Posted 04 December 2011 - 06:07 PM
looking at the listing should it say a + engines.
but it does say all gearboxes,
#73 liirge
liirge
  • 4,097 posts
Posted 04 December 2011 - 07:21 PM
I wouldn't rely on eBay for accurate product descriptions.....
#74 Cooperman
  • 23,569 posts
Posted 04 December 2011 - 08:13 PM
When top-quality gaskets are available from the likes of Mini Spares, why would anyone buy stuff of unknown quality off ebay just to save a few quid and risk having to do the whole job all over again?
#75 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 December 2011 - 08:36 PM
Seriously - these gaskets are only paper thin - the thick gasket IS the problem.......
