Hi,
I've only used the new forum and I think it is very good.
I've installed many phpBB sites and I think IP board is much slicker and user friendly....but.... I never used the old one and don't know what it was or what it was like, however from a 'new persons' view I think TMF works well.
My negative comments on the system are:
1) bad search function
2) inability to edit posts after a set time, as already mentioned. I sometimes write replies on a phone and after I've posted the number of mistakes I've made are numerous. If I haven't noticed them in time my post is left in an unreadable state.
And, as others have said the mobile view is very good.....
On the negative thead comments a la 'just use the search' etc I've seen a few but it doesn't seem to be a problem. I'm only really active (and very new) in the Problems sub forum though and a better search will prevent posting the same question over and over.
When Vista first came out, most people hated it. They preferred the older look, found XP easier to use and said it was far less buggy. Yes, it was far less buggy, but what can you expect from a totally new revamp? Then, people started to work out how to use it properly, and got used to it. They realised that Vista had just the same functions as XP did, with more. They also found it was a lot quicker to use than XP, and a lot easier over time.
As an aside XP is slower than Windows 7 due to extra code levels on top of drivers. Gamers tend to use XP for that reason.
Charlie
Edited by charliedurrant, 29 November 2011 - 10:14 PM.
