Unable To Pump Brake Fluid Through To Rear Cylinders
94 replies to this topic
#1 Lord Lucan
Lord Lucan
  • 117 posts
Posted 03 December 2011 - 12:48 PM
Car stood for 5 years,,, loosened all pistons and renewed a rear brake pipe. Topped up with brake fluid but none appearing after 50 pumps...
Anything obvious im missing?
This is it....
Looking forward to shows in the new year ... any ideas?? Thanks.
Edited by Lord Lucan, 03 December 2011 - 12:48 PM.
#2 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 03 December 2011 - 03:53 PM
My fluid after standing went to jelly thick and misty colour, disconnect pipes from the cylinders so you have an open end
and see if you can get fluid through, or it could be air locked first bleed front brake furthest away then closest then try the rear brake furthest away try a Gunson pressure bleeder worked on mine but you may need to help it by pumping the pedal
#3 dow62
dow62
  • 355 posts
Posted 03 December 2011 - 08:21 PM
Never had to try it on any of my cars, but had several motorbikes that i had trouble with bleeding the calipers. Got round it by connecting a syringe full of brake fluid to the bleed nipple, injecting it back up to the master cylinder, usually got things flowing.
#4 Carlos W
Carlos W
  • 10,115 posts
Posted 03 December 2011 - 08:40 PM
You could try leaving the peddle partially pressed overnight! I've had that work with the brake leaver on motorbikes
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 03 December 2011 - 08:44 PM
Rubber brake hoses collapsed?
#6 dow62
dow62
  • 355 posts
Posted 03 December 2011 - 08:58 PM
Done that before also on some of my bikes, allows air bubbles to rise naturally back into master cylinder resevoir. Worth a try as long pipe runs allow ( nowhere for air locks to hide ) . Bike hoses a lot shorter though.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 03 December 2011 - 09:54 PM
Seized up pressure limiting valve? Test at the valve outlet(s) if you have one.........
Edited by bmcecosse, 03 December 2011 - 09:55 PM.
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 03 December 2011 - 10:11 PM
Following along Bmcecosse's comment, I suspect the brake valve on the rear subframe.
If you pump the brake pedal hard or fast it can shuttle the valve to a closed position which will prevent fluid from coming out. There are two methods I have seen work around this problem.
1) Disconnect the brake pipe just before the brake limiting valve and let the fluid pour out of there for a second or two, then reconnect it to the valve.
2) Open one of the rear bleed nipples with a brake bleeder hose attached (and in a catch jar) and go away for a while. Gravity can/will allow fluid to flow slowly through the system pushing air out ahead of the fluid.
#9 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 03 December 2011 - 10:41 PM
not been stupid here am i? but dont they limit or disconnect the rear brakes on shorties???
im sure the ones ive seen and drove, had a limiter to the rear brakes, i think its to stop the car spinning when braking hard?
Investigate the system and see if its been messed with?
#10 firefox
firefox
  • 1,102 posts
Posted 03 December 2011 - 10:47 PM
the above has twigged my memory i could not bleed the brakes and i rang M machine he told me to undo the pipes at the limiter on the bulkhead and pump the pedal until i got fluid then tighten and bleed the brakes
it was an airlock in the master cylinder
Edited by firefox, 03 December 2011 - 10:48 PM.
#11 dow62
dow62
  • 355 posts
Posted 04 December 2011 - 10:34 PM
Any progress with rear brake problem Mr Lucan ?
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 05 December 2011 - 12:52 AM
He's gone away for a while.............
#13 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 05 December 2011 - 04:43 AM
also a trick that has worked for me . is jack the back as high as you can get it ... i had my car with 2 spares wheel stacked on top under each side then blead . it worked a treat
#14 Lord Lucan
Lord Lucan
  • 117 posts
Posted 06 December 2011 - 06:46 PM
couple of drops showed over weekend...
What if I put some pressure in the master cylinder (heath robinson setup), with the pedal pressed half way down?
#15 Lord Lucan
Lord Lucan
  • 117 posts
Posted 06 December 2011 - 06:47 PM
Wanting a matching wheel too... if you know where one is... Thanks
