Unable To Pump Brake Fluid Through To Rear Cylinders
#31
Posted 06 December 2011 - 09:42 PM
#32
Posted 06 December 2011 - 09:54 PM
well i am so sorry must be a hard jobI stand corrected....I only work on Mini's every day at work so don't know what I'm on about
i have been a petrol head for 42 years, so i dare say i outrank you
Edited by firefox, 06 December 2011 - 09:54 PM.
#33
Posted 06 December 2011 - 10:00 PM
I was not bringing your experience into any sort of question just stating a fact i learnt through trial and error. It worked what can i say.
#34
Posted 06 December 2011 - 10:16 PM
put so nicelyHaving had previous experience with easi bleeds etc in the early 90's with a lack of front brakes that i could not get my head around and numerous other engineers all scratching their heads pumping the brakes at the same time as using the Easi bleed cured the problem. Also another member of the forum who has a serious amount of experience with Mini's tried the same trick with his Mini and hey presto his brake problem was sorted.
#35
Posted 06 December 2011 - 10:26 PM
First one to get air out of my system..... pulls the trigger on the devilbliss spray tan gun.....
#36
Posted 06 December 2011 - 10:29 PM
WOWEEEEEEEEEEEE WHERE DO YOU LIVE I AM ON THE WAYand miss lucan can i do your next tan spray ha ha ha only joking
#37
Posted 06 December 2011 - 10:39 PM
help a damsel in distress
#38
Posted 06 December 2011 - 10:45 PM
Bloody Hull stuck out on the edge of nowhere
#39
Posted 07 December 2011 - 05:11 PM
Caused quite a scene ..........
Eezibleed was nowhere to be seen..... So I had a thought
What if I cut the schrader valve off an old inner tube - and then drill a hole in a plastic top with the thread matching
the master cylinder filling hole............. Success..... Just pump the naughty fluid through with a bicycle pump...
Edited by Lord Lucan, 07 December 2011 - 05:18 PM.
#40
Posted 07 December 2011 - 05:46 PM
That is genius well done girl glad it's sortedWell today I walked to the shops..........
#41
Posted 07 December 2011 - 06:08 PM
#42
Posted 07 December 2011 - 06:13 PM
#43
Posted 07 December 2011 - 06:44 PM
But will keep my roving eye on it... Thanks
by the way - The pedal is like it's had double viagra.......
Edited by Lord Lucan, 07 December 2011 - 06:47 PM.
#44
Posted 07 December 2011 - 06:50 PM
#45
Posted 07 December 2011 - 06:52 PM
Never seen/thought of that before.
