Custom Dash Build (Fully Digital)
45 replies to this topic
#1 cstarke
cstarke
  • 15 posts
Posted 16 January 2012 - 08:02 PM
Hi all
I'm busy designing a fully digital dash that uses a 10.1" galaxy tab for both gauges and I.C.E. Just thought id post some pics of the design stage to see what you guys think.
I would like to keep the air vents as it gets very hot here in South Africa so fresh air is a must, but i would also like dash mounted speakers and at least one small cubby hole. Space is a bit of an issue so any suggestions or ideas are more than welcome
Chris
Attached File  mini dash 2.jpg   195.94K   261 downloads
Attached File  mini dash.jpg   144.67K   76 downloads
#2 billok
billok
  • 228 posts
Posted 16 January 2012 - 08:26 PM
you could try a few designs with the pad flipping down from under the dashboard
#3 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 16 January 2012 - 08:28 PM
I would loving something like that so i could intergrate my Ipad 2 into the dahsboard
#4 A362 TTU
A362 TTU
  • 525 posts
Posted 16 January 2012 - 08:30 PM
How will you see the galaxy tab screen in direct sun?.
#5 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 16 January 2012 - 10:11 PM
As your building from scratch, move the speakers to the outside and the air vents in.
Much better place for the speakers. And air vents can be anywhere really.
Edited by Ruckus, 16 January 2012 - 10:12 PM.
#6 RobWill116
RobWill116
  • 256 posts
  • Local Club: DCMOC
Posted 16 January 2012 - 10:32 PM
How are you planning on integrating to gauges and ice into the tablet? If you know android progamming the app wouldn't be too difficult to design but it would be tricky to get a reading for the speedo connected to the tablet!
#7 cstarke
cstarke
  • 15 posts
Posted 16 January 2012 - 11:05 PM
Thanks for the great response :)
The sun is an issue but i am not too worried about that as tyhere is nothing i can do about it.
I can write android apps and i will use an arduino micro-controller connected to the tablet to read speed rpm etc straight from the car.
Thanks for the idea ruckus i will definitely give that a thought.
The Tablet will slide into a custom mount so i can remove it when not in the car so i can use it and so that its not stolen :P.
please keep the ideas coming :)
chris
#8 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 17 January 2012 - 08:46 AM
Tell me more... Do you have a link to these controllers, could one talk to more than one tablet at a time and can they talk to a pc or mac?
If you're a dev can you code apps if other platforms??
I have ideas.... ;)
Edited by Ruckus, 17 January 2012 - 08:46 AM.
#9 cstarke
cstarke
  • 15 posts
Posted 17 January 2012 - 11:03 AM
http://www.amarino-toolkit.net/ this is the project thats connects the two and this is the micro controller http://arduino.cc/ and yes arduino's can be connected to mac pc linux android and pretty much anything with usb or bluetooth.
The controllers are quite cheap and can talk to each other so multi tablet connection probably wont be a problem.
I wouldnt call myself a developer as im only just learning the coding or the android apps however i have worked allot with the micro-controller.
please share your ideas as i want as many as possible so when i do write the app it is all inclusive..
chris
#10 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 17 January 2012 - 12:22 PM
Can they cope with the analog input from the speedo cable ?
#11 cstarke
cstarke
  • 15 posts
Posted 17 January 2012 - 09:02 PM
Instead of the speedo cable i will use a hall effect sensor some where on the output side of the gear box. Not quite sure yet though. For RPM i will use a clip on RPM sensor over one of the spark cords. I'm still busy figuring out the logistics but hopefully i can make it simple and reliable
#12 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 17 January 2012 - 11:03 PM
might help... http://www.dakotadig...=cat/cat311.htm
Edited by Ruckus, 17 January 2012 - 11:10 PM.
#13 Cunnymonster
Cunnymonster
  • 368 posts
  • Local Club: Colchester Mini Club
Posted 17 January 2012 - 11:10 PM
Id love something like this, good luck!!!
#14 RobWill116
RobWill116
  • 256 posts
  • Local Club: DCMOC
Posted 18 January 2012 - 03:43 PM
Very good idea, you obviously know what you're talking about! If you ever get one fully working thats reliable, you could make some serious money from it by creating a similar app for ipads and a universal connection for other cars. Keep us updated!!
#15 freshairmini
freshairmini
  • 1,718 posts
Posted 19 January 2012 - 11:32 AM
was thinking that when i first saw this, thers so many things you could incorporate into it as well, like megajolt integration, that would be cool!
