Thieves Siphoning Fuel
76 replies to this topic
#1 zeroasylum
zeroasylum
  • 378 posts
Posted 12 March 2012 - 02:58 PM
For the 4th time in about 8 months now I have had all the fuel siphoned out of my mini. That is annoying me. What is more annoying is the thieves who are clearly targeting the car (I live in north London and have no option but street parking) Keep taking the lockable petrol cap with them which means I end up spending another £10 pounds on one. No I know them taking the fuel is better than me fitting an anti-siphon device and them cutting the fuel hose or scratching up the car but is there any way I can get my car alarm to go off if for example the petrol cap is removed via a switch eg magnetic or some method or from the tank sender unit sensing a drop in tank level. Any advice welcome
Zeroasylum
#2 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 12 March 2012 - 03:00 PM
ive looked into this as its happened to me a couple times.
your best bet is to relocate the filler neck to inside the boot.
i had a quote for £100 to modify the petrol tank so you could only access it by opening the boot.
#3 coopdog
coopdog
  • 4,506 posts
Posted 12 March 2012 - 03:05 PM
try and make a small alram yourself!,
im sure local electrictions will help,
i would think it wouldnt be too hard?
make a simple circuit, try and get your hands on a switch which works via a magnet or such link that to the battery via a proper feed get a big massive horn so when it goes off it scares them and wakes you up and other people,
thats what i would do.
#4 freshairmini
freshairmini
  • 1,718 posts
Posted 12 March 2012 - 03:09 PM
Or if you park it in your street (outside your house?) fit a cctv camera, and put a note your mini saying there being watched. You can get cheap cctv from maplin, worth a thought maybe?
#5 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 12 March 2012 - 03:28 PM
you could maybe use a small LDR (Light dependant Resistor which you could wire up so as the light hits the device it would cause it to change its level of resistance to low allowing current to flow through... not sure if this would be a viable option though
#6 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 12 March 2012 - 04:02 PM
And if it's dark? :P
#7 zeroasylum
zeroasylum
  • 378 posts
Posted 13 March 2012 - 09:23 AM
Was thinking about this. I do have a microwave proximity sensor attached to the alarm but have it set so it only works when really close to the car as it kept going off with other passing cars. Maybe will have to adjust it to extend the field of the sensor. Do you think it would be possible to get a magnetic switch to trigger an imput on the alarm system in the same way a push pin bonnet switch does.
Zeroasylum
#8 zeroasylum
zeroasylum
  • 378 posts
Posted 13 March 2012 - 09:26 AM
Again a good Idea unless they cut the fuelpipe but dont think they are that smart. But would petrol fumes not enter the car as a result of the opening in the boot. I not sure how well the caps seal. Also how does insurance view this mod.
Zeroasylum
#9 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 13 March 2012 - 09:43 AM
You should have a fuel pipe vent going out the floor of the boot anyway so fumes shouldnt be a problem.
#10 se_juggles
se_juggles
  • 1,043 posts
Posted 13 March 2012 - 10:31 AM
Just spend a months spying on your mini and if you see them have a baseball bat ready.... and yer I'm sure you can make an alarm I have little button lilhr things in the boot and under the bonnet and if you open either while the alarm is set they pop up and set the alarm off so would be a case of fitting a smaller one under the fuel cap I guess
Stupid question but do you buy lockable fuel caps?
Edited by se_juggles, 13 March 2012 - 10:32 AM.
#11 freshairmini
freshairmini
  • 1,718 posts
Posted 13 March 2012 - 10:38 AM
I wondered that... How do thieves get into a locked one, do they drill it?
#12 Alex_B
Alex_B
  • 4,573 posts
Posted 13 March 2012 - 10:52 AM
they are a bit springey so i guess they get something under the cap and use a hammer or something
#13 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,726 posts
  • Name: Chris
  • Local Club: None
Posted 13 March 2012 - 11:01 AM
How about an alarm that goes off when the fuel sender drops below a certain level, it will deter theifs and will tell you when your running low as mini fuel gauges arnt that reliable anyway
YetI
#14 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 13 March 2012 - 11:02 AM
They're not exactly 'strong'.
my locking cap's been taken before I've even started driving :lol: ...They didn't take any fuel though?!
#15 Nikral
Nikral
  • 274 posts
Posted 13 March 2012 - 11:17 AM
This is an invention waiting to happen, obviously there is a demand among the classic car owners ( whatever make) to stop thieves sucking the petrol out of your car.
