Clutch Pedal Like Concrete
57 replies to this topic
#16 MGBailey007
MGBailey007
  • Validating
  • 725 posts
  • Local Club: North West Mini Club
Posted 18 March 2012 - 10:37 AM
unlucky its well easy to get too on mine haha
#17 reallybig
reallybig
  • 613 posts
Posted 18 March 2012 - 10:40 AM
got the car running now anyway by removing the air filter.....
yeah got ecu in way, break master cylinder and fresh air couling for heater
Edited by reallybig, 18 March 2012 - 10:41 AM.
#18 MGBailey007
MGBailey007
  • Validating
  • 725 posts
Posted 18 March 2012 - 10:44 AM
your clutch is working now?
#19 reallybig
reallybig
  • 613 posts
Posted 18 March 2012 - 11:06 AM
nope clutch doesn't work and i've now somehow broken the rev counter by putting the air filter back on..... what the hell
#20 MGBailey007
MGBailey007
  • Validating
  • 725 posts
Posted 18 March 2012 - 12:22 PM
haha i think you are now using a select few words right now
#21 reallybig
reallybig
  • 613 posts
Posted 18 March 2012 - 01:34 PM
think i bled it properly and no change
sprayed wd40 over the clutch housingy thingie hopefully that'll do something if not am i really going to have to remove the slave cylinder?
#22 alexw89
alexw89
  • 53 posts
Posted 18 March 2012 - 01:38 PM
Had the same problem with a freinds mini,
Remove the 2 small bolts holding the ecu bracket (not the posi drive screws as you cant get to the last one) manouvre it out the way and when you can see the clutch arm tap it with a small soft faced hammer towards the slave cylinder and it will return to the engaged position, now apply a generous spray of wd40 or similar all over it and see if you can work the clutch using the pedal, if you can push it once then it goes solid again repeat the tapping it back and try working the clutch again,
sounds a bit primative i know but worked a treat for me and it saves removing the clutch etc.
Hope this Helps!
#23 reallybig
reallybig
  • 613 posts
Posted 18 March 2012 - 02:36 PM
can't rly get a hammer between the rod bit and the wing
#24 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 18 March 2012 - 02:41 PM
the plunger on the clutch is a pain but a nice long bar and a tappin stick, then a goos squirt of brake cleaner and wd40 on the plunger
#25 reallybig
reallybig
  • 613 posts
Posted 18 March 2012 - 05:00 PM
less than 2cm between the panel and the plunger thing
can't get hammer in there and bar just starts to crack the fresh air inlet
bah
#26 tiger99
tiger99
  • 8,584 posts
Posted 18 March 2012 - 06:15 PM
You are barking up the wrong tree anyway. Nothing that responds to WD40 etc happens overnight. If it was ok one day, and locked solid the next, it is not just rust or lack of lubrication. And, there was no way that bleeding was going to cure it if it was locked solid.
You need to do some dismantling of the clutch mechanism for a look, not pointless hammering.
#27 reallybig
reallybig
  • 613 posts
Posted 18 March 2012 - 07:01 PM
going to dismantle it anyway, was just hoping for an easy solution....
see if it's sunny tomorrow
#28 MGBailey007
MGBailey007
  • Validating
  • 725 posts
Posted 18 March 2012 - 07:03 PM
best of luck
#29 reallybig
reallybig
  • 613 posts
Posted 18 March 2012 - 07:24 PM
probably a stupid question but do i need to completely drain the clutch system to remove the slave cylinder
#30 MGBailey007
MGBailey007
  • Validating
  • 725 posts
Posted 18 March 2012 - 07:28 PM
just suck out what is in the reservoir the rest will just drip out with gravity
