Pre Verto Clutch Adjustment
#16
Posted 18 May 2012 - 09:32 PM
#17
Posted 18 May 2012 - 09:42 PM
Bend the arm towards the slave cylinder - I bet it works then!
To be honest I'd rather fix it properly thankyou
And ok I will have a look at it tomorrow and see what this distance is and let you know thankyou for your help it has been very usefull
#18
Posted 18 May 2012 - 09:46 PM
#19
Posted 18 May 2012 - 09:54 PM
#20
Posted 18 May 2012 - 09:58 PM
#21
Posted 18 May 2012 - 10:00 PM
#22
Posted 18 May 2012 - 10:09 PM
#23
Posted 18 May 2012 - 10:15 PM
#24
Posted 18 May 2012 - 10:28 PM
But if it works for some, then fine.
#25
Posted 18 May 2012 - 10:32 PM
#26
Posted 18 May 2012 - 11:09 PM
I'd rather do it properly I am going to check the travel tomorrow and go from there I'll post on here again tomorrow with the results and get some advice on where to go , if it is below 0.5" shall I order the slave sylinder and hose and start there ?
If it's less than 0.5" check for free play in the lower clevis pin which holds the arm to the clutch cover. It is lower down on the arm and if it wears a lot it can cause the same symptoms. Take a look at the 'faultfinder' posted above.
#27
Posted 18 May 2012 - 11:17 PM
#28
Posted 19 May 2012 - 08:54 AM
Sadly, it is by far the most awkward area of a Mini to work in, unless you are a contortionist. The usual way is to take the seats out, and put down some cusions on the floor so you can lie on your back.
#29
Posted 19 May 2012 - 10:15 AM
If the travel is too small, also check the pedal, clevis pin and master cylinder push rod for wear. Usually, the clevis pin seems to be quite hard, but the pedal is mild steel and the hole may elongate, which will cause lost travel.
That clevis pin has to be the most awkward job on a Mini. I had to change a clutch master cylinder on a fellow-competitor's Cooper 'S' in the town square in Cortina d'Ampezzo after a Pirelli Classic Marathon. What a palaver that was. Still, he did buy me a beer or three afterwards.
By bet would be on the slave cylinder if the arm travel at its top is less than 0.5", but it could well be something else. The 'fault-finder' I posted above will identify it if followed from the beginning.
Right, off to tidy and clean up my workshop for the rest of the day.
#30
Posted 19 May 2012 - 12:41 PM
