Pre Verto Clutch Adjustment
#31
Posted 19 May 2012 - 12:58 PM
#32
Posted 19 May 2012 - 03:57 PM
#33
Posted 19 May 2012 - 04:20 PM
Do I have to remove anything else to change the cylinder ?
#34
Posted 19 May 2012 - 04:33 PM
I did measure from the top and most times it looked under 0.50" so I think I'll order a new cylinder and hose ? Is this right ?
No, it should come straight off.
Undo the return spring, undo the hose and take out the 2 off 3/8" UNC bolts (that's 9/16" AF spanner size). Undo the hose from the end of the pipe which comes from the master cylinder to the bracket on the bulkhead, replace the hose there first, then attach the cylinder and fit the new hose. Bleed out with new fluid. Use a piece of rag to prevent any clutch fluid from going on the paintwork when you disconnect it - brake/clutch fluid is the finest paint stripper known to man!
Good luck with this. Come back here for any further advice you might need.
#35
Posted 19 May 2012 - 04:50 PM
Thankyou for your help it has been great
#36
Posted 19 May 2012 - 06:41 PM
#37
Posted 19 May 2012 - 09:08 PM
Edited by bmcecosse, 19 May 2012 - 09:12 PM.
#38
Posted 25 May 2012 - 05:47 PM
#39
Posted 25 May 2012 - 06:41 PM
#40
Posted 25 May 2012 - 07:03 PM
#41
Posted 25 May 2012 - 07:15 PM
Putting it into reverse when the choke is keeping the revs higher than that will always cause a 'graunch' (Love that word!).
#42
Posted 25 May 2012 - 07:36 PM
#43
Posted 25 May 2012 - 07:40 PM
#44
Posted 02 June 2012 - 12:58 PM
Is your idle speed high?
I'm having similar problems and mine is high. What does this indicate?
#45
Posted 02 June 2012 - 04:25 PM
It indicates that you need to adjust the idle speed to the correct figure.
