Pre Verto Clutch Adjustment
Jwatts93
, May 16 2012 07:47 PM
47 replies to this topic
#46
Posted 02 June 2012 - 04:53 PM
#47
Posted 02 June 2012 - 05:09 PM
Is your idle speed high?
I'm having similar problems and mine is high. What does this indicate?
It indicates that you need to adjust the idle speed to the correct figure.
It was idling around 800. The clutch started slipping about a fortnight ago, so I tried adjusting today without much joy and notice that revs are up on idle. Probably a coincidence.
Anyway, I've read a few comments that the arm should move freely by hand, but mine won't budge a millimetre by hand.
#48
Posted 02 June 2012 - 07:32 PM
I turned the mini over yesterday and took choke of pretty quickly and so tickover was under 800 and still has a crunch is there anything else I can try ?
