Hello Everybody! Just Got My Graduation Present. Can You Guess What It Is? :)
#31
Posted 14 June 2012 - 06:34 PM
Nice looking Mini :)
#32
Posted 15 June 2012 - 08:14 AM
#33
Posted 15 June 2012 - 08:16 AM
#34
Posted 15 June 2012 - 11:28 AM
theres no reason it shouldnt do 65-70mph for hours on end, just will be louder and a slight twitch of the steering wheel seems 5 x worse at that speed compared to a modern car
from the pictures of the engine you put up it looks pretty standard, cant tell if it has a non standard exhaust system
have fun!
#35
Posted 15 June 2012 - 11:30 AM
its got a MG metro rocker cover. which is from a 1275.
short journeys are generally harsh on engines, make sure its warmed up before you rag it and give it a nice drive out if you can.
Maybe it has a 1275 engine? I'd be thrilled if it did.
How could I tell? Yeah - I'm an utter novice; this is my first car. :)
the engine is yellow though, meaning it is only a 998cc....unless its been re painted.
type the engine number on this site and it will tell you clicky
#36
Posted 15 June 2012 - 01:21 PM
Welcome to the mini scene. It's like no other. Oh and general driving 65mph will seem fine.
#37
Posted 15 June 2012 - 02:20 PM
#38
Posted 16 June 2012 - 06:13 PM
#39
Posted 17 June 2012 - 01:19 AM
#40
Posted 23 June 2012 - 06:42 PM
#41
Posted 23 June 2012 - 07:38 PM
Welcome to TMF :)
Nice looking Mini and looking at that engine pic it is not standard cause its like mine
Open air filter shows its got a stage one kit (well part of it may need some more)
Mines same as urs and mine does 75 easy.... thats full of gear and it was broken cause balljoint has worn and cause wheel wobble(may have to do that soon
if you have nothing at bottom then it may just need a tune... not hard really
Bit of advice to keep it goin:
1. Get electronic ignition for it
2. Get a massive adio system for it so you can hear it
3. look after it like a baby
Enjoy your mini experience :)
#42
Posted 23 June 2012 - 08:10 PM
heres mine which is a 25 to compare
#43
Posted 23 June 2012 - 08:15 PM
#44
Posted 24 June 2012 - 10:51 PM
She was fine until the toll bridge queue, hitting 60-70 absolutely no prob. On the bridge, however, after sitting for a few minutes developed a HORRIBLE judder when pulling away from stationary and 1st>2nd gear. Put up with it for a short while, but after continually juddering for a few minutes she cut out, and I had to push her to hard shoulder. Called RAC and tried starting her in the mean time (she wouldn't start for a good 30 minutes) but -- sod's law -- by the time he got there she was starting up again. He looked at the engine and said it looked/sounded fine! I managed to drive it the remainder of the way but it is still juddering HORRIBLY when I accelerate in 1st/2nd, I'm cringing every time I pull away at a set of lights! Not good...
I have no idea why, all I can think is there might be sediment in the petrol tank from sitting for years. This is the first major run she's had i a long time. The clutch is new as far as I know - and there's only around 9000 on the clock.
Edited by CBW, 24 June 2012 - 10:59 PM.
#45
Posted 25 June 2012 - 07:29 AM
This car looks (and sounds) like a real gem with only 9k on the clock, please look after her
After sitting about for so long, I would remove the carb float chamber, remove all the sediment and ensure the float needle-valve is functioning correctly, now would be a good time to install an inline fuel filter, I usually put them right after the tank, in the rubber hose. Like you say, removing the tank and giving it a good flush/ shake out is an excellent idea.
After you have done all that, renew the points, cap, rotor and spark plugs and you'll have a reliable runner :) None of the above is difficult or particularly time consuming.
The City 'E' is great as an everyday driver because it has the 2.95:1 fd, which gives relaxed cruising at higher speeds and much improved economy; if you look at the performance figures, it is barely any slower than the similar cars with a 3.44:1 diff, even though they do bog down just a little when pulling away...
