Calling All Suck Thru Sc's
#46
Posted 23 January 2013 - 08:21 AM
#47
Posted 23 January 2013 - 09:28 AM
Aldon red d45, but looking at the down load off the website i'm thinking of getting an ignitor.Awesome sounds good, what dizzy you going to be using with it?
#48
Posted 23 January 2013 - 01:49 PM
I will probably end up buying one
#49
Posted 24 January 2013 - 02:15 AM
Although looking at it, it would not be as accurate. Losing some accuracy through the dizzy.
Edited by jonny f, 24 January 2013 - 02:24 AM.
#50
Posted 24 January 2013 - 11:05 AM
#51
Posted 08 February 2013 - 06:08 PM
I think the comment that Smart performance are responsible for a ring failure should be removed. You have no evidence of this. My guess is that you have detonation which has caused the head gasket failure and piston failure. As Phil says, more likey ring lands than rings. So the reality is that either your installation is flawed and either making too much heat or the CR is too high. Or possibly the RR guy ran it lean or with too much advance.
No. 4, failing would definately suggest to much heat and running into det. Your engine may benefit from dry decking and a bypass hose on the flywheel end of the engine.
In my experience of failed ring lands, little damage is done to the bore. A new set of pistons and a hone should be all that is needed. You could maybe consider a piston with a bigger dish.
Out of interest could having the cam timing out 9 degrees (116 degrees) cause detonation ?
#52
Posted 11 March 2013 - 08:59 PM
Don't need to scratch around getting bits, installing trigger wheel etc, use existing dizzy, cheaper. looks easier to install. I'll be on the phone to them tomorrow to place my order. Exciting stuff.
What are the benefits over mega jolt?
So if I wanted a basic supercharged set-up (not silly power) - a supercharger kit, plus this Aldon Amethyst bits, a quick RR set up and off you go?
#53
Posted 12 March 2013 - 09:23 AM
#54
Posted 12 March 2013 - 07:52 PM
Hi, don't suppose you've got the maps on pdf or on a spread sheet?get rid of the dizzy its just point less . ive got a few good 1293 supercharged megajolt maps round
#55
Posted 12 March 2013 - 07:56 PM
As tommy say's-Jus like that!
Add time and patience
