Calling All Suck Thru Sc's
#16
Posted 15 July 2012 - 07:09 PM
just hook to laptop to tune
#17
Posted 15 July 2012 - 07:13 PM
#18
Posted 15 July 2012 - 07:17 PM
does the software come with the megajolt? (the idea is starting to snow ball in my head now. see what you've started!)you just need to trim the engine mount bracket . then toy can still get the belts on an off
#19
Posted 15 July 2012 - 07:18 PM
got any pic's? i like pic's
#20
Posted 16 July 2012 - 08:35 AM
#21
Posted 16 July 2012 - 10:11 AM
http://www.autosport...tallation_guide
start there
i had mine hooked up on the floor of the mini . wires every where . and it started first pop
ive got no pics that are really help full .
Edited by new_zealand _minis, 16 July 2012 - 10:17 AM.
#22
Posted 16 July 2012 - 08:31 PM
parts are cheap really
start there
Getting more interested. Where did you have your map? Vacuum pipe used for dizzy before or off inlet manifold between charger and head?
#23
Posted 16 July 2012 - 08:33 PM
start there
Do you still need a coil?
#24
Posted 16 July 2012 - 09:15 PM
start there
No coil needed...
#25
Posted 16 July 2012 - 09:22 PM
http://www.ausmini.c...4937&highlight=
#26
Posted 17 July 2012 - 06:17 PM
I have the prototype of this kit... Fits to a standard pulley as long as you have the tapped holes.
http://www.ausmini.com/forums/viewtopic.php?t=74937&highlight=
I didn't realise the trigger wheel went on the inside. Is there a crank pully with a trigger wheel built in anywhere?
#27
Posted 17 July 2012 - 06:18 PM
start there
No coil needed...
Thatsgood
#28
Posted 18 July 2012 - 08:26 AM
#29
Posted 18 July 2012 - 10:54 AM
How easy is it to take the crank pulley off with the engine in the car?
Remove rad - loosen fan belt - put jack under engine - remove engine mount bolts - jack up engine - remove rad/engine mount bracket - lock flywheel - undo pulley and remove. simple.
#30
Posted 18 July 2012 - 12:20 PM
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
