Need To Lower My Car
Posted 11 August 2012 - 10:05 PM
Posted 11 August 2012 - 10:18 PM
Posted 11 August 2012 - 10:47 PM
For road use lowering is not really a good idea as the disadvantages far outweigh any perceived advantages.
Posted 11 August 2012 - 10:49 PM
If you want to trim the cones, you have to get it right or at least err on the side of caution. You'll have to remove them to cut them down, measure how much you want lower then divide by 3 for the fronts and 5 for the rears, chop that off and replace.
On the rear you'll likely have to add a washer to the end of the trumpet - best welded in place and of course it's thickness taken into account when cutting (you'll need to remove it's thickness too).
Also consider as your cones wear you may want to alter the height upwards, if cutting you have to add more washers to do this. For the cost, hi-lo's are really worth it.
Edited by Skortchio, 11 August 2012 - 10:51 PM.
Posted 11 August 2012 - 10:55 PM
Why would you need to add a washer? You can't weld a washer, invariably made of steel, to an alloy trumpet anyway.
But as Cooperman said, you do not need to lower any Mini for road use, in fact it will be distinctly unhelpful, as you will have wrong geometry at the front, the roll centre height will move unfavourably, etc. Taken to extremes, lowering puts lives at risk due to ball joint failure.
Posted 11 August 2012 - 11:01 PM
As for lowering for road use, would it not be beneficial in terms of accurate setting of the suspension and geometry to have hi-lo's?
Not specifically for lowering, but to equalise the height across the car to account for discrepensies in the tolerance of the Mini design, as well as front to back height.
If you go to the trouble of correcting the camber and toe etc. Is that not also optimised by having the car at recommended height?
Edited by Skortchio, 11 August 2012 - 11:17 PM.
Posted 11 August 2012 - 11:36 PM
Minor adjustments to take up tolerances can, if necessary, be accomplished by a very small amount of metal removal or fitment of a thin washer.
Some of the adjusters on the market are known to collapse after a while due to fatigue failure. I find the quality of many aftermarket parts currently available to be depressingly low. It was not always so, and good, safe height adjusters did exist. They probably still do, but not for £40 a set.
Posted 12 August 2012 - 10:34 AM
Posted 12 August 2012 - 11:25 AM
cutting your trumpets down or a cheap hilo copy won't
Posted 12 August 2012 - 11:51 AM
Cutting down the trumpets is far safer than using some of the trash HiLo kits currently on the market.
+1
Posted 12 August 2012 - 12:14 PM
as well is lowering buying a real hilo from minispares will alter the spring rate for the lowered ride
Erm... What? 0.o
Posted 12 August 2012 - 12:59 PM
Posted 12 August 2012 - 01:03 PM
Easiest and best option is to get Hilo's or Adjustr-rides, stay clear of cheap chinese copies.
Posted 12 August 2012 - 02:31 PM
