712 replies to this topic
#61 SAL 821X
SAL 821X
  • 1,891 posts
Posted 05 November 2012 - 08:10 AM
How do you mean Ryan, the hinge holes on the doors or on the A-panel?
I'd take it for you but I don't have any doors on mine at the moment.
#62 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 05 November 2012 - 10:49 AM
Sorry I should be more clear the holes on the back of the van from passenger side to drivers side lowest bolt hole from the rear door hindge cheers !:)
#63 ChrisCityE
ChrisCityE
  • 418 posts
Posted 05 November 2012 - 11:10 AM
Just did a quick measurement, on my Van but is on its side and doesn't have the cross brace on it.
The width of the 4 holes, centre to centre are (TOP to BOTTOM)
995mm
1005mm
1075mm
1080mm
Edited by ChrisCityE, 05 November 2012 - 11:10 AM.
#64 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 05 November 2012 - 12:10 PM
Cheers bud! Now I can get it in the right place XD need to find a bit o steel first tho hmmmmmm
#65 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 06 November 2012 - 04:57 PM
Right done some work today thanks to ChriscityE for the measurements ! Couldn't find a good enough bit of metal to go across so used a bit of wood instead ! does the job! lol XD
Now at least i know the drivers side rear post is in the correct place and the door gaps will be ok!. Also found out it has been in an accident this side and had to remove a quarter inch of filler from the hinge area and knock the dent out (should of been done like this before! ) need to find a way of twisting the post as well as its been slightly pulled from were it was hit.
Welded the rear corner repair partly in need some more cutting discs to double cut it across and seam weld the join up
and here is a picture of the hole that the door catch goes through taken from under the car!
Will get some cutting discs asap and hope to get the drivers side finished cant belive i have used 13 already!
cheers!
#66 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 11 November 2012 - 04:44 PM
got some discs from screwfix today! so i cut and clamped the panel with my intergrips
Tacked it and removed the grips
started to weld in different places each time to avoid distortion
fully welded
ground it all down and sprayed some 182 over the top :)
Also welded up the holes on the other side that were covered with tacked on patches
I will be starting on the other corner next! cheers !
#67 SAL 821X
SAL 821X
  • 1,891 posts
Posted 12 November 2012 - 09:16 AM
Nice repair Ryan.
I can't see the door catch on mine from the underside as the valence is in the way.
#68 666junky
666junky
  • 1,225 posts
Posted 12 November 2012 - 10:20 AM
Lovely work, I must come and oogle at it when its finished!
#69 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 12 November 2012 - 01:41 PM
Nice repair Ryan.
oh right well i think there are are a few different versions :)
cheers mate!
#70 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 12 November 2012 - 01:42 PM
Thanks alot! Hopefully if i get my arse in gear that will be sometime soon! im going to go work on it some more now! :D
#71 ChrisCityE
ChrisCityE
  • 418 posts
Posted 16 November 2012 - 05:21 PM
Keep at it, I'm looking at getting my Van finished by June/July next year...
#72 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 18 November 2012 - 07:08 PM
Good luck im thinking around the same time! Update incoming!
#73 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 18 November 2012 - 07:17 PM
Update!
I have fixed the driverside rear door post that was bent by cutting it, bending and re-welding it on was the only way it would straighten out :) here it is re-welded on
started on the passenger side this afternoon so I got the sandblaster up and running and blasted out the box section under the floor and gave it a coat of 182
Double cut the floor repair and welded the edge on to the wheelarch
Tacked and intergrips removed
Fully welded in Looks a bit crappy but it was all done without a mask as mine has broken! so im facing the other way when welding! Got it down to an art! haha
Ground it down and bit of primer over the top to protect. Used my new 40 grit flap discs i got from the NEC classic car show on friday :D
The rear end is looking better! door step and inner valence next!
More updates when i get round to doing some more!
#74 YoungUn
YoungUn
  • 488 posts
  • Local Club: F.A.B.M.O.C
Posted 19 November 2012 - 12:27 AM
Nice project mate! i love reading other van projects
Charlie
#75 SAL 821X
SAL 821X
  • 1,891 posts
Posted 19 November 2012 - 08:27 AM
After 9 years in the making! I'm hoping to have mine done around the same time.
Mini Van road trip anyone? ;)
