Tuning The Injection Mini
#16
Posted 11 September 2012 - 05:52 PM
http://www.minimania...information.htm
#17
Posted 11 September 2012 - 10:00 PM
Remap a SPI ECU is impossible. The design of the electronic inside board doesn't allow it.
For the MPI it's possible, because you have an external EPROM who can be removed, red, modified then fitted again with richer injection tables. The problem is that no engine tuner spend a single second on this subject ... Siemens's (if I remember good) ECU are not well known and it's too much work for an old MPI cars. Engine tuner prefers Bosch ECU for TDI motor, the money is the first reason :).
Cheers,
Phil
#18
Posted 12 September 2012 - 08:29 AM
MPIs all have the same ECU.
#19
Posted 14 September 2012 - 07:43 PM
Cheers,
Phil
#20
Posted 15 September 2012 - 10:06 PM
Here's a copy and paste of the engine and gearbox bits. I spent dozens of hours looking into this. Hope it is of use to you.
- New rocker studs & new head studs
- Duplex timing chain and gear
- 1330 cc
- SW5 camshaft
- Turbo head gasket
- "Stage 3" head (35/7mm inlet, 29mm exhaust valves)
- Polished crank,
- New big ends and bearings,
- P21253-60 x 4 pistons,
- Fully rebuilt gearbox with modified ratio for 10" wheels
- Centre oil pick-up, moly differential pin, helicoil sump plug
- Standard flywheel &
- Turbo clutch
- Raised c.r. to 10:1,
- MNE101070 Cooper E.C.U.
Am only aiming for 85bhp as the Spi injectors can't handle much more than that according to Sprocket (Spi TMF guru) and just after some fun, not speed
Edited by cliche, 15 September 2012 - 10:09 PM.
#21
Posted 15 September 2012 - 10:14 PM
#22
Posted 15 September 2012 - 11:42 PM
Hi, do you have the specs of such SPI modification ? Could be interesting to see what can be done.
Cheers,
Phil
Yep, tomorrow i'll look for the regulation book, its all written there
#23
Posted 16 September 2012 - 02:02 AM
yupPresumably that's an SW5i cam?
#24
Posted 16 September 2012 - 07:18 PM
#25
Posted 17 September 2012 - 09:25 AM
Cheers,
Phil
PM sent!
#26
Posted 18 September 2012 - 05:49 AM
I look after a few mighties: the supers have more modifications than the standards.Hi, do you have the specs of such SPI modification ? Could be interesting to see what can be done.
Cheers,
Phil
The regulations detailing all the modifications allowed in the series can be found on the website: www.mightyminis.co.uk :)
ttfn,
Dave
#27
Posted 22 September 2012 - 09:16 PM
Thanks you Jaydee for sending me the specs.
Cliche : I have rebuilt my 1275 with your specs, but 12755cc, kent 274i & a 1.5 lift ratio rocker.
I didn't have rolling-road it, but my feeling is that I need to give it more fuel. If you do compare the given power with a carb' engine, there is a few horses to bring back under the bonnet.
Icklemini : Did you have seen SPI car from the challenge ? If so, did you seen the specific SPI mods ?
Cheers,
Phil
#28
Posted 23 September 2012 - 02:52 AM
Something that can be modified?
Maybe something like the external Superchips, but it is an in-effective solution at best.
Edited by tmsmini, 23 September 2012 - 02:55 AM.
#29
Posted 23 September 2012 - 05:37 AM
Yeah i look after a few... got one coming in today for a bit of work....Icklemini : Did you have seen SPI car from the challenge ? If so, did you seen the specific SPI mods ?
#30
Posted 24 September 2012 - 08:17 PM
I said there is a lot of interesting stuff on this board (click the photo to ZOOM it) :
BLUE : it is the CPU, the only processor, a Motorola MC68332, no instruction or data in it.
RED : the EPROM, 27C1024 (size 65K x 16Bits) all the MPI software is in it, alarm handling, injection table, but no "volatile" information
YELLOW : the EEPROM, C66 (means 93C66, size is 4Kb) all the faults code, alarm encoding, learning is store here
I have start the reverse of this ECU long time ago, but as my MPI get stolen by bastards and then I bought a SPI, I left this job unfinished.
This means if someone spent time on this ECU, it can be FULL reprogrammed. An urban legend to said the MPI can't be remapped ! It's just a problem of time/money/knowledge.
To be clear, let's talk about SPI. Unfortunately for the SPI the CPU plus the EPROM is in a SINGLE component, who can't be read. Means, it's IMPOSSIBLE to have access to the code as said above. The MNE 1010XX CAN'T be remapped. End of the story...
After, the system as TMSMini show, a piggy-back system if I name it correct in English, is a not so bad solution : the extra added ECU trap the injector signal and send it back a little wider, so the opening time is changed. It means that the engine run rich.
IckleMini, about the Mighty Mini, I just understood it's only SPI on the lane
How much BHP those engines achieves ??? Did you notice some mods worth to be done on our engine ???
Cheers,
Phil
Edited by phil242, 24 September 2012 - 08:20 PM.
