nice job on the front end, looking mucho neat!
looking at the front end before you ripped it off it looked like it had quite a bit of filler in there as well, bonus on getting rid of that!
and as others have said, literally ram paint into that seam before you go over with sealer, and on the back seam as well, before sealing that also! and for sealing, run a bead into the seam, then run your finger along it, pressing it in, but without removing the seam completely and making it look de-seamed:) and when you dont, let it go tacky ( not dry completely ) and then put primer over it. you do this becuase if the sealer was dry, the paint wont stick to it, and the paint will crack after a few months. if paint is applied when the sealer is tacky, the paint sticks and flexes with the sealer when you are driving along. the paint will not crack:) bit of a tip there for you
what are you going to do about the corrosion on the inner wing, flitch panel and floor where the subframe mounts, it may all be surface rust now, but you may be replacing that front end in a few years time if you dont conquer it now!
My Poor Mini
Chance
, Sep 26 2012 02:31 PM
52 replies to this topic
#46
Posted 11 October 2012 - 11:11 AM
#47
Posted 11 October 2012 - 11:41 AM
Thanks for all the hints on the sealer :)
As for the surface rust I did get it back to metal and treat/paint it, probably should of done better but I really need my car!!! I can live with the fact I may be doing it all again in a couple years maybe, I gave everything a good prod with a screw driver and didnt make any holes.
I havent touched the floor yet as my windscreen leaks, I'll be changing this at the weekend I hope and I'll wire brush/grind away at the floor to see the damage
Was all a learning process really, I'm quite happy for a first time.
Theres other areas on the car that need addressing and as ssoon as I find a car that I canafford to insure ill be treating the minI to a de-rust session :)
#48
Posted 11 October 2012 - 06:55 PM
You're doing much better than I am lol!
Looks good, well done!
#49
Posted 11 October 2012 - 06:59 PM
Cheers man
I saw you said that m-machines didnt have the panels in stock youll get it done im sure!! :)
#50
Posted 12 October 2012 - 01:27 PM
It was Moss, they were doing a 20% discount at just the right time for me.
Didn't mention they were out of stock though.
I'll have plenty of time to practice my welding I suppose. I'm a bit pish at it so far . haha
#51
Posted 13 October 2012 - 05:05 PM
Right so got it back together today
Have had to make do with bonnet for now( may be buying when shortly) and the paint is naff but it does the job and I'm saving for group 2 arches now and also gonna get my minilites refurbed and sell the revos
Got my lights working ( changed the switch on a whim)
However I now dont have the battery light on ignition, the red one
I noticed it was dodgy after id crashed but now it doesnt work at all :/
Edited by Chance, 13 October 2012 - 05:06 PM.
#52
Posted 13 October 2012 - 05:12 PM
Doesn't look bad in the picture, I like the new grille
#53
Posted 13 October 2012 - 05:16 PM
Ive got to sort a new bonnet strip and paint it black.
But that will wait til I get a bonnet :)
Cheers mate, pictures make everything look good haa
Edited by Chance, 13 October 2012 - 05:16 PM.
