My Poor Mini
Chance
, Sep 26 2012 02:31 PM
52 replies to this topic
#16
Posted 27 September 2012 - 04:13 PM
Malvern show
#17
Posted 27 September 2012 - 11:12 PM
I get mine from minispares
#18
Posted 28 September 2012 - 11:56 AM
Will be making a trip to minispares today to get most things :)
Hows yours going now mate??
In other news ive started taking the lights out today and come across a problem that may have an easy solution but im too thick to see it.
These connections are for the lights obviously but they do not fit out of the headlamp bowl as they are too big to fit through the hole?? Im guessing these were added as an extra at some point.
Is there anyway i can pull the connections out of the block or not?? Shall i just cut the bowl?? But then how will i get them in the new ones??
Any help is much appreciated
#19
Posted 28 September 2012 - 12:46 PM
It's ok I was being stupid
Disconnected in the middle!!! Sorted
Now to start grinding!!!
#20
Posted 28 September 2012 - 06:27 PM
Right to managed to remove thw drivers wing ish
This part of the inner wing and the front where it's bent will need attention!!
#21
Posted 28 September 2012 - 06:42 PM
should have straighted the inner wing with the old wing before removing it
#22
Posted 28 September 2012 - 06:49 PM
Ohhh right :/
I figured I'd get a new wing and straighten it to the fit the new wing or even make a new front using the other side as a template and weld that on??
#23
Posted 28 September 2012 - 07:12 PM
wish it was that easy, do u have a slide hammer?
#24
Posted 28 September 2012 - 08:06 PM
I dont think there was a chance of me pulling it with the wing
It was quite squashed!! I tried to straighten it with the front panel and it wernt having any of it
I can get one i'f needs be but I dont have one no
Can you get repair panels for the front inner wing?? This was another idea i had.
#25
Posted 29 September 2012 - 02:51 PM
i have straighten worse and not replaced a wing. If it only got the front 50% better, the thing is you have something to thump and push that does not matter , where as whats left does
dave
dave
#26
Posted 29 September 2012 - 05:28 PM
Good point
I have managed to get it somewhere near straight with some persuasion and using the front panel that was still attatched, the front is quite corroded anyway
This is where ive got so far
#27
Posted 29 September 2012 - 05:40 PM
sorted
#28
Posted 29 September 2012 - 06:11 PM
Nearly there :)
Ill remember your tip for the future :) cheers mate
#29
Posted 30 September 2012 - 12:39 PM
lets just say I have done a few repairs on front ends without replacing the panels by a bit of pushing the front forward, Its one thing an old 8.4" brake disc is good for
#30
Posted 01 October 2012 - 08:33 PM
Okay so as this is my first time at replacing panels
How do I weld the new wing on?? Plug weld??
Drill holes in the new panel or do it the other way round??
