My Poor Mini
#31
Posted 06 October 2012 - 01:26 PM
They are pattern parts but there is a big gap up by the scuttle
Like nowhere near right!!
#32
Posted 06 October 2012 - 02:39 PM
#33
Posted 06 October 2012 - 02:45 PM
Usually..
-The return lip on the wing(where it welds to the inner wing) is too big and causes the wing to sit further out, grind it back till the wing to bonnet gap is right(don't take too much off!!)
-The return lip by the scuttle fouls on the scuttle causing a big gap, gently bend/tap/grind it back until it clears and the gap is nice.
They take an age to get right, I've done a few and allow a days worth of messing around before I even get to weld it on.
Daves right with the self tapping screws, use them to temporarily hold it in place, you'll also need a shedload of mole grips.
Good luck
#34
Posted 06 October 2012 - 06:49 PM
#35
Posted 06 October 2012 - 07:08 PM
Thanks for the tips guys :) Ive got to finish getting it all lined up tomorrow after a lot of messing today, I'm enjoying it
#36
Posted 06 October 2012 - 07:20 PM
do you want me to pop up and give you a hand to get it lined up? you have got my number, give me a text if you do.
you will at least have new wings now! dont forget i have got loads of paint for this if you want it too.
#37
Posted 06 October 2012 - 07:29 PM
I felt so bad
I was gonna text you for a hand but didnt want to bother you again, must be sick of the sight of it now!!
I have managed to change just the front panel and drivers wing, probably wouldnt be suggested but mainly for speed as I need it for work and everything else!!
#38
Posted 07 October 2012 - 09:53 AM
#39
Posted 09 October 2012 - 04:53 PM
The seams arent too bad but I understand some of you guys use abit of seam sealer to seal them??
Whats best to buy?? ( best = cheap but good )
Ive got to use the car regardless now for work, ive painted the panels and I might laquer it today but to use the sealer id have to undo my painting I suppose??
#40
Posted 09 October 2012 - 04:57 PM
#41
Posted 09 October 2012 - 05:08 PM
Well ideally I would have done it before paint and painted over it but I just need to use the car now havent got a choice kind of thing
Edited by Chance, 09 October 2012 - 05:13 PM.
#42
Posted 10 October 2012 - 10:09 AM
#43
Posted 10 October 2012 - 06:08 PM
Before you use the seam sealer, run as much thinned zinc primer as possible into the seams, or spray with a rattle can from very close range, masking the other paintwork. Repeat a few times. When you are sure that you have as much zinc as possible in there, then you can seal them.
Thanks for the tip :) will make sure I get something in there :)
#44
Posted 10 October 2012 - 06:37 PM
#45
Posted 10 October 2012 - 10:30 PM
